Opinion on 2 10 inch box - Car Audio Classifieds!
Old 06-19-2013, 08:14 PM
lkraft97's Avatar
0/11 sssssss20
Default Opinion on 2 10 inch box
hey CACO. i want your guys opinion on this box. its made for 2 older rockford 10 inch subs running on around 300 watts total. i'm not sure of the displacement but they are't very big, i'm guessing .05 a piece. do you guys think this would work? this will be my first box i have built, so any info would be awesome. thanks.
Old 06-19-2013, 08:25 PM
Mr.G6's Avatar
0/11 sssss4614
uhhh there isnt any info besides a picture
we need a LITTLE more than that lol
2000 Gmc Sonoma ext cab
Old 06-19-2013, 08:35 PM
lkraft97's Avatar
0/11 sssssss20
ok what other info do you need? i got all of the dimensions on the torres calculator. the subs are 8 ohm each, and will be wired in parallel to 4 ohm with about 350 watts.
Old 06-19-2013, 08:43 PM
Mr.G6's Avatar
0/11 sssss4614
ok well whats the net cubic feet? tuning? and how much port per cube?
id say something like 2 cu ft net mid 30hz tune and 13 to 14"per cube
also..just from MY personal experience..you might see loading issues with the woofers like that.. i always try to keep them on the SAME baffle
Old 06-19-2013, 08:44 PM
0/11 ssss31258
it'll work.
the bottom of the vertical 10 mounting flange would have a problem with your vent radius..
If it were mine, I would continue the vertical piece to the vent for structural reasons.
Also, I wouldn't bother routering anything except the mounting holes... and that's only if you already have a router.
I'm a screws and glue guy. I'd rather have a strong / structurally solid enclosure which the effort was placed in the actual building than having a weak pretty enclosure where more effort was put into making it look nice than strength.
Old 06-19-2013, 09:18 PM
lkraft97's Avatar
0/11 sssssss20
Mr. G6-all of the tuning info is in the torres calc, the net volume-1.01, tuning-35, and port area per ft-13 inch. i really cant go any bigger with my volume without totally changing my plan. i would like to put the box in the middle of my back seat and i cant go any bigger without it interfering witht the ofther 2 seats. i am a noob to audio so i'm still trying to learn the terms. what do you mean my loading? if its a major problem, i can just get rid of the sub on the top and just go with one. thanks for the info
iamsonic- i wasn't going to router all the edges since this is my first box. also the cutouts for the subs are 10 inches, the actual cutout for the sub would be smaller anyways. thanks for the input.
Good, 3+ cf ported box for a 12 inch sub or a box builder (central WI) Wingman0121 Wanting to Buy (WTB) 0 06-16-2012 08:58 PM
Does this look good for a 4 15"s box? (in your opinion) jt_buck General Car Audio Discussion & Questions 4 04-06-2011 04:04 PM
4 15"s box, give me your opinion grimreper912003 General Car Audio Discussion & Questions 9 03-29-2011 01:47 PM
lvl 5 12" box, post your opinion based on exeperience fit4lyph (DC) 3 02-03-2011 01:53 AM
2 12 Inch Box help SPL_II Enclosure Discussion & Design Construction Help 4 09-16-2010 11:54 PM
