Single FI Sp4 D1 6th order in a sedan - Car Audio Classifieds!
Old 06-20-2013, 06:59 PM
0/11 sssssss39
Default Single FI Sp4 D1 6th order in a sedan
Old 06-20-2013, 07:02 PM
0/11 sssssss39
Toyota Corolla
250 Amp alternator
XS Power 3100 and Shiruken 140 AH
Single 15 FI Sp4 D1
Alpine CDA-136BT
Autotek MM4000.1d 2 channel 2 ohm
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
all front chambers are to small... there 1.5 cubes and 3.8 cub ft
Rear should be around 2.5 to 4 depending on power so that ones close
Old 06-20-2013, 07:04 PM
0/11 sssssss39
From what I have researched, you are completely right! What I am curious of, why does it look good in the program and what is going to happen in reality? Just trying to learn more about 4th and 6th order boxes and would love to understand better. Thanks
Old 06-20-2013, 07:05 PM
Authorized Vendor
0/11 ssss14115
Front tuning needs to be alot higher as well, around 60/65 range
Old 06-20-2013, 07:06 PM
Authorized Vendor
0/11 ssss14115
Winisd will tell u it can't accurately model 6th orders
Click the "l" for liters and change it to ft^3
Old 06-20-2013, 07:09 PM
0/11 sssssss39
SA8v2 4th order/6th order/Vented melverc Enclosure Discussion & Design Construction Help 0 10-07-2012 10:44 AM
pair of 8s in a fourth order blow through in sedan Ringspun09 General Car Audio Discussion & Questions 10 04-29-2012 01:03 AM
