4th order port placement - Car Audio Classifieds!
Old 06-21-2013, 07:05 AM
0/11 ssssss273
Default 4th order port placement
If building a 4th order shiyld subs fire at port or across it. For example this will be in a jeep and if the sealed portion has subs facing roof and port facing front of vehicle or should I have both subs and port facing the front which would have the subs firing partially into the port.
Grand Cherokee
Mechman 240, Mechman 270, 4 runs 2/0, d3400 under hood, 6 31's agm in rear, 4 silver flute 6.5, 8 vifa 1", 2 sk85.4, 2 zvx 18, 2 sk2500.
Too much electrical is better then not enough.
Suburban build coming soon. Collecting parts.
Old 06-21-2013, 07:37 AM
Micksh's Avatar
0/11 sssss2596
All to front, and try and get the subs on a flat wall if possible.
My Youtube page
Astro build log link
Old 06-21-2013, 10:15 AM
0/11 ssssss273
Ok. Now if I do it all facing the front I would have limited space between sub and port. The box would only be roughly 30 deep but from ceiling to floor so most air space below sub which seems like it wouldn't perform well.
Grand Cherokee
4th order port help jstang2003 General Car Audio Discussion & Questions 4 03-01-2013 11:32 AM
port area 4th order constantprojects Enclosure Discussion & Design Construction Help 28 05-15-2012 12:39 AM
Port or 4th order rsfaze (Sundown Audio) 7 03-07-2012 07:43 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
4th order/slot port help king ranch Enclosure Discussion & Design Construction Help 26 08-03-2009 10:53 PM
