aero port question - Car Audio Classifieds!
Old 06-21-2013, 06:46 PM
0/11 sssssss59
Default aero port question
can anyone help? does anyone know if 6" thin wall pvc pipe will work with aero pipe flares and connecting rings? i have a 24" piece of it and it sure would make the cost more reasonable if it would work.
Old 06-21-2013, 06:51 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Of course it'll work...if u plan to heat mold it ull want to be easy with the heat though
Old 06-21-2013, 07:08 PM
0/11 sssssss59
heat mold? how do i go about that?
Old 06-21-2013, 07:14 PM
Authorized Vendor
0/11 ssss14115
U said aero...aero has flares (rounded end) which can be done by heating it with a heat gun over a rounded object
Its just a round port if u use it as straight pipe so yes, it'll work fine
If u wanna try heat molding, watch this
this - youtube
Old 06-21-2013, 07:15 PM
0/11 ssssss322
I think Jeff was thinking you were going to make your own custom flares using a mold, a heat gun, and the PVC tube.
You are saying, will the ABS plastic AeroPort flares and connectors that you purchase work with the PVC pipe instead of buying the original ABS pipe you can buy for it, right?
I have not done this with the 6", but I have with the 3" and 4". The factory supplied connecting rings will not fit over the PVC pipe. You you have to buy the PVC connectors, and possibly build up the flare ends with some tape before putting together.
It's not quite as perfect as all the stock parts, but it does make testing multiple port lengths much more economical.
Old 06-21-2013, 07:20 PM
Authorized Vendor
0/11 ssss14115
Lol, atleast he knows what/how to heat mold lol
Old 06-21-2013, 07:23 PM
0/11 ssssss322
^^ Exactly!!! Now he doesn't even have to buy the flares if he doesn't want to!! : )
Just a $ store bowl and a board!!!
Old 06-21-2013, 08:24 PM
0/11 sssssss59
i just thought it might be easier to use the aero port flare than trying to make my own flare
Old 06-21-2013, 08:42 PM
vince79vette's Avatar
0/11 sssss2011
They have green sewer pipe at lowes and homedepot and with alittle heat it is like silly putty. Really nice stuff
Old 06-21-2013, 08:50 PM
0/11 sssssss59
how did you get the end of the flare flat?
another aero port question BBear Enclosure Discussion & Design Construction Help 12 01-04-2012 09:53 PM
aero port question Ringspun09 Enclosure Discussion & Design Construction Help 3 12-01-2011 05:34 PM
aero port question More spl General Car Audio Discussion & Questions 4 04-11-2011 09:28 AM
question about aero port oslouie Enclosure Discussion & Design Construction Help 4 03-04-2011 09:43 PM
aero port question cadillac214 General Car Audio Discussion & Questions 13 10-19-2010 01:42 PM
