Single FI Sp4 D1 slot ported in a sedan - Car Audio Classifieds!
Old 06-22-2013, 01:50 PM
0/11 sssssss39
Default Please confirm this is a GREAT Single FI Sp4 D1 slot ported box for sedan
Last edited by Artrilliance; 06-22-2013 at 01:58 PM. Reason: Title change to clarify post
Old 06-22-2013, 01:54 PM
0/11 sssssss39
3.5" slot port would be tuned to 28.39 hz
4" slot port would be tuned to 30.65 hz
Everything else looks good?
Old 06-22-2013, 05:06 PM
0/11 ssssss247
If I'm reading your drawing right, the port would be 14.25 x 4?
If so that is only 57 sqin of port. Way small.
Old 06-22-2013, 05:37 PM
0/11 sssssss39
I have already tried adjusting port length and it starts eating up net box volume and takes a great deal more length for minor adjustments in tuning. I'm pushing to go for the larger box, smaller 4.5" port of around 14" cu in per foot, and keeping the tuning lower. Will this be a good compromise? My trunk space is maxed out and I feel from the WinISD graph that the larger box will have a smoother curve as well as gain closer to 3DB. How is it looking?
Old 06-23-2013, 01:00 AM
0/11 sssssss39
Bump?
Old 06-23-2013, 01:10 AM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
external aeroports work great in trunks
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 06-23-2013, 01:22 AM
Contributor
0/11 ssssss109
I had Sp4 in a 4.5 net cube single 8" sonotube, 30hz on 3.5k watts in a trunk and it was ridiculous on lows
Old 06-23-2013, 07:37 AM
Mr.G6's Avatar
0/11 sssss4614
total fail of a box for a sp4
take our advice and get more port area
2000 Gmc Sonoma ext cab
Single FI Sp4 D1 6th order in a sedan Artrilliance Enclosure Discussion & Design Construction Help 6 06-20-2013 06:09 PM
ported or 4th order 2 fi sp4 15s dwhite General Car Audio Discussion & Questions 23 02-01-2013 04:28 PM
1000wrms sub w/ slot ported enclosure GrnNGrls Hot Deals 10 11-06-2011 12:43 PM
Slot ported box for 2,15" Manhattan's jessdabest77 Enclosure Discussion & Design Construction Help 0 08-29-2011 07:49 PM
Anyone Ever Seen A Slot Ported..... only126db General Home Audio/Video 6 12-08-2009 04:23 PM
