Best port/sub configuration in an extended cab? - Car Audio Classifieds!
Old 06-23-2013, 06:44 PM
0/11 sssss1741
Default Best port/sub configuration in an extended cab?
Ive never messed with an extended cab truck before, but about to put a system in one. Its an 02 ram 2500. Going to be removing the rear seats for the box. Its a buddies truck, he said it has about 18x26x54 for space. We were thinkin three 15's but after he gave me measurements I don't think there will be quite enough space.
The power will be an aq3500. was thinking of three hdc3 15's at first. Might have to drop it down to two 15's, hopefully they take the aq3500 well if it comes down to that.
Mostly I am wondering what works best for sub and port configuration in a truck like this. I was assuming subs firing up. port either firing up or to the front but really have no idea.. does anyone have any experience with the same truck? If not I am sure what works best in most extended cabs would be real similar to this. Oh ya and both doors in the back open up
EDIT also if anyone knows what the new hdc3's like for box that would be nice. I am trying to search for that right now but if anyone knows off hand that would be great.
Old 06-23-2013, 07:15 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Subs either up or forward
port up off to one side
Old 06-23-2013, 07:17 PM
916slapin's Avatar
0/11 ssssss825
subs up port up looks brutal
4 DC XL 15s Doing a Hair Trick ON ROCK - YouTube
http://youtu.be/Z-mtnCEho7E
Old 06-23-2013, 09:20 PM
0/11 ssssss214
I got extended cab Silverado. I run subs up port up. For 2 ab xfls on a bc2k it gets down enough to get some light hair moving a little. Nothing crazy. Taken apart atm or I'd give u a vid.
Sent from my ADR6425LVW using Tapatalk 2
Old 06-23-2013, 09:22 PM
0/11 sssss1741
Subs and port up it is.. . now just trying to figure out if three 15's will fit in it.. its a tight fit if it even will work
Old 06-23-2013, 10:22 PM
0/11 ssssss214
You can definitely fit 3. You might have to sacrifice some seat lean for it though.
BESt 10" sUB FOR EXTENDED cab?? Jesus805 General Car Audio Discussion & Questions 4 10-01-2012 01:47 PM
extended cab dakota right...subs up, port up or what? beatnbronco General Car Audio Discussion & Questions 9 10-11-2011 10:55 AM
2 SA-12s in an extended cab S10 NPHagert Enclosure Discussion & Design Construction Help 24 06-05-2011 10:36 PM
09 Silverado Extended Cab Substage Hertz5400LincolnLS Enclosure Discussion & Design Construction Help 3 03-08-2011 08:57 PM
Best option for extended cab silverado ado General Car Audio Discussion & Questions 5 11-02-2008 12:12 PM
