Help! Box doesn't perform the way I hoped - Car Audio Classifieds!
Old 06-24-2013, 02:17 AM
0/11 ssssss542
Default Help! Box doesn't perform the way I hoped
Driver : DD 512 d4
Box : 4th order (my first attempt)
1.05 sealed side with 1.75 ported side. Slot port 2x13.5 that's 15.5 inches long. I believe this puts me in the high 40s on tuning.
Problem : box peaks WAY too low. It's an absolute monster from 25-32hz. Anything above 40hz is much quieter and kicks drums are almost not heard.
Amp: saz1200d at 2 ohms.
I'm thinking about taking a piece of the port out to increase tuning to upper 60hz range. Or should I play with objects in the box to decrease volume of one of the chambers?
Thanks in advance for the help
Old 06-24-2013, 02:52 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Have u tried giving it more power than 600rms? What's wrong with a strong low end (32hz and lower) and I weak top end (36 and up)? That's how I like mine, lol
Sent from my DROID RAZR using Xparent BlueTapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 06-24-2013, 02:54 AM
0/11 ssssss273
The port you have is like a regular port for a ported enclosure, if you look at other 4th orders the port is wide and open and also short. You need to make the mouth of it a little wider and shorten it up, it you are comparing it to a ported enclosure time it into 50Hz first that way you can see if you'll like it. (It's always easier to cut vs add wood lol) hope this helps and add some pics of what you have now then when you finish so we can see progress :-)
Old 06-24-2013, 11:27 AM
0/11 ssssss542
I've tagged a pic of the inside, the sub is rated 350rms and after rise I'm sitting about 440 clamped on music.
I'm going to try and raise the tuning by making the port shorter today.
Old 06-24-2013, 11:31 AM
0/11 ssssss542
nothing wrong with it at all. its cool to play some of decafs lowest songs and feel the bass more than hear it lol. but that s not my everyday musical preference. I'm focused on a -3db bandwidth from 34ish to 65ish hz.
Old 06-24-2013, 12:05 PM
0/11 ssssss542
ok, so I removed the entire side of the box and port wall, shrink the port down to about 5 inches. raised tuning somewhere into the high 60's or lows 70's. made a HUGR difference. so now i'm going to play with some 3/4 mdf pieces to add anywhere from .75 to 3 inches in port length and see how it goes. wish me luck!
Old 06-24-2013, 12:11 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Originally Posted by hotshot27 View Post
Driver : DD 512 d4
A slot port with 2 x 13.5 opening with 1.75 cubes is going to be tuned at 45-46 hz if it's 15.5 inches long. That's if the port doesn't bend, like if it just goes straight back.
Old 06-24-2013, 12:15 PM
0/11 ssssss542
it does bend, so that would explain why my tuning was so low. I was probably 42-44hz?
Old 06-24-2013, 12:41 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Ya, you were tuned low, relative to a 4th order.
Old 06-24-2013, 12:49 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
more port for christ sake!
Chop the port off.
Widen it
Put it about 10'' deep
vamo
System not as loud as I hoped..HELP! kdubbin General Car Audio Discussion & Questions 23 05-17-2013 11:53 PM
WTB: Tweeters that perform very well off-axis Ge_off_me Wanting to Buy (WTB) 10 06-08-2012 08:41 AM
How does AQ subs perform with bandpasses? jprix82 General Car Audio Discussion & Questions 5 01-22-2010 12:31 AM
How will this box perform king ranch Enclosure Discussion & Design Construction Help 0 08-02-2009 10:34 PM
