Help me build a box for SP4 Gra - Car Audio Classifieds!
Old 06-26-2013, 12:34 AM
0/11 ssssss136
Default Help me build a box for SP4 Gra
I have 2 SP4's but think that I can only fit 1. Please give me your input. My max box dimensions are
41" width
30" depth
16" tall(window line) willing to go to 20" if needed
Help me build the optimal box please. Probably going with aero ports to save space.
Thinking sub up port back
Probably only gonna run 1 woofer because I don't think there's gonna be much of an output difference due to the box being too small for two.
Also running off an ab500.1 on solid electrical
All input appreciated
Thanks
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 3000W | 3000W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Sub OD: 18.500 | 18.500
Cut ID: 16.750 | 16.750
Mounting depth:11.750 | 11.750
Displacement: 0.26cuft | 0.26cuft
Old 06-26-2013, 09:02 PM
0/11 ssssss136
17.5 x 40 x 30". Slot port 28.5 x 4". 16sqin port.
7.12cuft.
31.73 hz.
Double baffle. Lots of bracing. Port up sub up. Port would be on one of the ends same side as sub
How does this look for a a single sp4
Old 06-26-2013, 09:16 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
7.12cuft.
31.73 hz.
if this is going in your cherokee, port back sub up should do good
if your looking for spl and daily, try 33hz tuning
dont care much about numbers, 31hz (what u calc)
7 cubes will work fine
Old 06-26-2013, 10:52 PM
0/11 ssssss136
looking to get loud daily....dont much care for termlab numbers.
Wanna move some air.
concern: only have about 4 inches between back of box and hatch. thats why i went port up. Think it will sound better port back? Any other concerns? Bout to head out to the Garage and start building
Thanks for your feedback so much appreciated
Old 06-26-2013, 10:56 PM
Authorized Vendor
0/11 ssss14115
jeeps (if i remember right) , do good either port up/sub up or sub up/port back.... so if you want to make it port up/sub up go for it... but your slot port is 4" so 4" of clearance would still work... you could also swap a dimension... for example...if the box was 10 tall and 20 from front of jeep to back, u could go to 11 and 19 to gain clearancde...just double check internal volume
Old 06-26-2013, 11:40 PM
0/11 ssssss136
What box calculator should i use? I have Torres Tuning but im kinda confused
Old 06-26-2013, 11:43 PM
Authorized Vendor
0/11 ssss14115
one of my favs
And
also good
Old 06-26-2013, 11:44 PM
Authorized Vendor
0/11 ssss14115
And for box volume use this
for finding volume
tricky0303 (06-27-2013)
Need a box designed for 2 FI Sp4 15s Optimus_Prime Enclosure Discussion & Design Construction Help 0 04-10-2013 01:10 AM
4 Fi SP4 Lincoln LS build. obibassoholic Build Logs 39 04-06-2013 09:35 PM
Box for 2-18" sp4 luis e General Car Audio Discussion & Questions 2 11-10-2012 11:59 AM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 02:43 AM
