3 sa10 or 2 sa12 - Car Audio Classifieds!
Old 06-26-2013, 11:51 AM
0/11 sssssss35
Default 3 sa10 or 2 sa12
With these measurments is either possible 33.25w*15h*17d ported around 32-34hz. Will be in 2007 charger ran off kicker zx2500.1 thanks for any info. Fyi i already have subs
Old 06-26-2013, 11:54 AM
0/11 ssssss182
3 10s would be more service area. I would go that route
Old 06-26-2013, 12:00 PM
Mr.G6's Avatar
0/11 sssss4614
service area were not talking about at&t lol
surface area cone area
i too would go for 3 10s option
2000 Gmc Sonoma ext cab
Old 06-26-2013, 12:23 PM
0/11 sssssss35
Would the enclosure be big enough is what i should have asked sorry
Old 06-26-2013, 01:39 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Id go w the 12s u will already be cutting it close after u subtract displacements for sub/port. U will lose more than u would gain imo w the 10s
Old 06-26-2013, 02:24 PM
0/11 sssssss35
What would i be losing
Old 06-26-2013, 05:36 PM
Team SPL Farms
0/11 sssss5000
Rms power per sub, the extra airspace u wouldve had had u used the 12s plus the surface area u would gain is almost null. Whats the value of the coils on the subs? This again is just my opinion man and id hate to steer you away from something if you would rather the10s! What is it u want to achieve w this? Numbers,or just good musical flexibility?
Old 06-26-2013, 10:35 PM
0/11 sssssss35
I would rather use the 10s but if the 12s would sound and work better with my app i will go with the 12s. I listen old school rap and r&b if that helps
Old 06-27-2013, 01:03 AM
Team SPL Farms
0/11 sssss5000
Honestly either one would be fine and have their own perks. The 12s will go a touch lower easier and are a little more efficent but you would need about another 1.25 cubes of space for the box.
SA-12 for SA10 ControlFreak Car Audio Trader (WTT) 4 01-14-2013 04:55 PM
2 sa10 fs fyerbyrd22 10" Subwoofers 23 12-06-2012 11:45 AM
2 sa10 on 3k fyerbyrd22 (Sundown Audio) 14 07-12-2012 04:34 PM
FS: Sundown SA10 jcp0420 10" Subwoofers 19 10-13-2011 01:45 PM
SA10 questions fox_racin4 (Sundown Audio) 6 06-03-2011 09:58 AM
