Ported box ideas. - Car Audio Classifieds!
Old 06-30-2013, 06:22 PM
oxsign's Avatar
0/11 sssss1876
Default Ported box ideas.
I'm looking at building my next box in my avalanche. As of now I have a single 15" on an [email protected] in 3.25 cubes. My next build will be the same amp on 2 TC9 based 12"s. the box will be roughly 5.65 cubes tuned to 32Hz. I was just "doodling" here at work and had a question. With a box that has an angle where is the best place for the port? Here are 2 drawings I made real quick.
1971 VW Fastback
Old 07-01-2013, 10:10 AM
0/11 ssssss384
Just curious. .. why the slant? Seems like going rectangular fixes the problem?...
Old 07-01-2013, 10:32 AM
Mr.G6's Avatar
0/11 sssss4614
is that 5.65 after displacements?
thats pretty damn big..
tc9 motors aint the strongest motors out there..best recones ive been able to get was like 1500w..and with the power you potentially have on tap..
id go with a smaller box on more power
2000 Gmc Sonoma ext cab
Old 07-01-2013, 11:03 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Old 07-01-2013, 11:27 AM
oxsign's Avatar
0/11 sssss1876
Sorry about that guys, I meant to say 3 TC9 based 12"s, not 2. The slant is there cause it's going in an avalanche and it need to be there in order to still fold down in order to use the blow thru bed (yes I use it and need it). 5.65 is ma max that I should have after all is said and done.
I'm just curious what affect the slant will have on the port & unloading. If it would be best to have it on the bottom where it's more straight? Or on the top with the angle? Or does it even matter?
1971 VW Fastback
Need you guys help with box four sundown zv3 18s ported box 12k rms. Mnorwood01 (Sundown Audio) 56 04-08-2013 04:38 PM
Good, 3+ cf ported box for a 12 inch sub or a box builder (central WI) Wingman0121 Wanting to Buy (WTB) 0 06-16-2012 07:58 PM
ported door panel ideas sonikaccord Enclosure Discussion & Design Construction Help 0 02-13-2011 08:23 PM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 03:17 PM
looking for ideas- single 8 ported sonicbluestx Enclosure Discussion & Design Construction Help 6 05-23-2010 02:39 PM
