Building a 4th order. Need help with tuning - Car Audio Classifieds!
Old 07-03-2013, 01:09 PM
0/11 ssssss256
Default Building a 4th order. Need help with tuning
I am building a 4th order that is .5 sealed and 1.5 ported. How do I figure out how big my port will need to be to get it tuned to around 50hz?? Also how deep into the box will the port need to be placed? I want the top of the port rising out of the box at least 6-10 inches.
Old 07-03-2013, 05:29 PM
briankeith1007's Avatar
0/11 ssssss374
Default Try this.
6inch port , 15 inches long.5 inches inside the box and 10 inches outside.
Old 07-03-2013, 06:15 PM
0/11 ssssss256
Six inch aero? Tube? Or square port?
I would like to go with a square port if possible
Old 07-06-2013, 01:06 PM
0/11 ssssss256
okay the box will now be .4 sealed and 1 cuft ported after sub displacement. What will my port size (length, width, height) need to be to tune it to 50hz?? I will only have about 5 inches inside the box and 3-5 inches outside the box for port. So basically the port has to be 8-10 inches in total length.
Also how much displacement will the port have on the ported side?
Old 07-06-2013, 03:03 PM
0/11 ssssss247
Where do you keep coming up with these numbers?
You can't just pick what you want the sealed and ported to be then make up a tuning frequency. It doesn't work like that. I'm not trying to be rude, just trying to help build something that will perform how you want. Making it up as you go along is not the way to go about it, especially on a bandpass. It a lot easier to screw up than a ported design.
Old 07-06-2013, 03:11 PM
0/11 sssss1085
Feedback Score: 23 reviews
Download winISD and try modeling your sub, it will give you a more realistic prediction for output and tell you what size vents are needed.
Old 07-06-2013, 06:20 PM
0/11 ssssss256
I got these numbers from Taylorfade. I told him I am building a box for two sa8v2's. He suggested .4 sealed and 1 cuft ported tuned at 50hz.. He used this same box with the sa8v1.5 and said it worked great. I need a 4th order design for two sa8v2's. I have 17" in hieght 18 inch in depth and 40+" width to work with. If anyone wants to help me out with a design I would apprecitate it.
Old 07-06-2013, 07:06 PM
0/11 ssssss247
Ok. It sounded like you were just picking numbers to fit what you had. If taylor already tried and designed this, what port area do you need? That will determine the length and if it will fit in your constraints.
Old 07-06-2013, 08:33 PM
0/11 ssssss256
I need 25 square inches. I have five inches to the motors inside the box and 7 " outside the box for port length.
Old 07-14-2013, 10:40 PM
0/11 ssssss211
No offense, but you clearly don't understand how these things work.
You can't decide your tuning frequency AND port area AND port length! You have nothing left to "vary" since you've already fixed all the variables! Unless you are God, you cannot make a 1 ft³ box with 25 in² of port area and 12" of port length resonate at 50Hz. Im-fuggin-possible.
One or more things HAVE to give. So once and for all, decide which things are to give.
Building a wall and need help with variable tuning fritt Enclosure Discussion & Design Construction Help 0 01-14-2012 05:46 PM
Rules/guidelines/tips of building 4th order bandpass AFlem Enclosure Discussion & Design Construction Help 3 01-04-2012 01:12 PM
4th order tuning question treylittlefield Enclosure Discussion & Design Construction Help 5 08-07-2011 01:07 PM
using a box building program for Hz tuning slamnride Enclosure Discussion & Design Construction Help 6 09-24-2009 05:11 PM
