6th for 2-15's. now...which subs to buy? - Car Audio Classifieds!
Old 07-06-2013, 01:06 PM
0/11 ssssss463
Default 6th for 2-15's. now...which subs to buy?
1:1.46 ratio 6th 26Hz rear(6cuft) / 48Hz front(9.2cuft).
I have a DD M3b for power on good electrical. I need the best subs for my power and available space. SUGGESTIONS? ANYTHING WRONG?
Old 07-06-2013, 08:45 PM
0/11 ssssss463
The choices would be sundown zv4's or tantric HDD's. kinda leaning toward the tantrics just in case I get mo powa' in the future. Any other choices I should consider?
Old 07-06-2013, 08:50 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
you dont buy subs for a box you buy a box for subs.
here is the EBP Stuff. i was a little off.
EBP - The efficiency bandwidth product, a rough indicator measure. A common rule of thumb indicates that for EBP>100, a driver is perhaps best used in a vented enclosure, while EBP<50 indicates a sealed enclosure. For 50<EBP<100, either enclosure may be used effectively.
EBP = FS / QES
EBP above 70, not too good in a 4th order, stick to ported or 6th
EBP between 40-70 either 4th or 6th would be fine
EBP below 40, probably best to stick with sealed applications
if you want it to work well in a 6th you want over 60. here is a calculator for that
Efficiency Bandwidth Product Calculators - EBP, Speaker Resonance Frequency, Speaker Electrical
The Following User Says Thank You to tony30cl For This Useful Post:
455dscdbh (08-19-2013)
Good 6th order subs??? jws84_02 General Car Audio Discussion & Questions 9 10-16-2012 02:10 AM
what subs should i buy jezus43130 General Car Audio Discussion & Questions 17 03-09-2012 06:56 PM
Lanzar Optidrive 15's in a 6th order...glove trick! Jolly Green Giant Car Audio Videos 37 02-09-2011 02:28 AM
Mikey's Hummer H2 Build Log - 8 15's, 6th Order Bandpass kane0249 Build Logs 32 08-08-2010 11:29 PM
subs for a 6th order jj53913 General Car Audio Discussion & Questions 11 05-10-2010 11:20 PM
