My 4th Order model for 2 Tantric Hdd 15's - Car Audio Classifieds!
Old 07-07-2013, 04:17 AM
0/11 ssssss256
Default My 4th Order model for 2 Tantric Hdd 15's
Whats up guys. Just messing around with sketch up and designed the box I am going to build for my Tantric HDD 15's. I got the cuft measurements from Murphy. It is 8 cuft ported after displacements and 4 cuft sealed tuned to 50hz.
Let me know what you think and if you have any suggestions.
0/11 ssssss256
how do you tag people in the posts?
Old 07-07-2013, 04:29 AM
0/11 sssss1417
suggestion would be bracing. ie the port
Old 07-07-2013, 04:49 AM
0/11 ssssss256
brace the port itself or around it? I am going to be using metal rod bracing throughout the box.
Old 07-07-2013, 06:48 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
i'd def double layer that whole box, not just the baffle.
spec wise seems legit
Old 07-07-2013, 09:35 AM
0/11 ssssss256
It will be made of 1" Baltic Birch. Still think I need to double it up?
Old 07-07-2013, 09:47 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
i believe you mean quote, not tag...click this button on the post you want to quote... in the bottom right of peoples replies
Old 07-07-2013, 09:49 AM
Mr.G6's Avatar
0/11 sssss4614
2 layers of 3/4" is 1.5" thick so yes even with the 1" thick wood id still use 2 layers OR brace the holy shit out of it and resin too
2000 Gmc Sonoma ext cab
Old 07-07-2013, 09:50 AM
Authorized Vendor
0/11 ssss14115
id brace that thing for all its got... do it once and do it right... other wise, ull loose output if the panels arent thick/strong enough or the box will slowly kill its self and ull have to buy/build another.... add internal bracing if you have the room if you want to save a lil cost vs making the whole box a little thicker...if u want to, make the box 1.5" birch... thats a box
the good thing, ull never regret to much bracing unless its in front of a port or you have no room to fit it in the boxes volume
Old 07-07-2013, 11:13 AM
Veteran Member
0/11 sssss3026
tagging system isn't enabled on this site.
other sites that have it you just do @username and it does it automatically from there.
07 Impala SS 4th order for 2 15's Whoodwhooker Build Logs 111 01-22-2014 07:51 AM
6 Zv3 15's in a 4th Order :) Oldbass38 (Sundown Audio) 13 06-18-2012 11:03 AM
Need Help with 4th order for 2 SA-15's bigdogjk (Sundown Audio) 3 01-08-2012 04:41 AM
4th order for 2 SA-15's bigdogjk Enclosure Discussion & Design Construction Help 0 01-07-2012 06:52 PM
8 15's 4th order wall possible? badmofo529 Enclosure Discussion & Design Construction Help 6 10-13-2011 07:37 PM
