Geo metro build ..need help - Car Audio Classifieds!
Old 07-11-2013, 02:02 AM
0/11 sssssss22
Default Geo metro build ..need help
So I got myself a 92 geo hatch and I have an orion hcca 150r amp that I wanna put to use , anybody know if this amp would work good with a 15 mojo and 4 6.5s
Old 07-11-2013, 02:12 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Doing comps or just for daily?
My game is legit,
Old 07-11-2013, 02:21 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
ORION HCCA 150R
if I remember right, it was rated 25x2 but did like 100x2 and 600x1
I can't find specs on it. Is it a 2 channel bridgeable amp?
Sounds like you can either run 2 channels or a sub from it.
BUT if you don't mind fader function, you can still hook up front and rear (or 2 mids and 2 tweeters) and retain balance functionality (fader can still be achieved via a PAC LC-1 or similar RCA level control (at $12.50 brand new on ebay, I don't see a need to investigate anything else though)
"6.5" is a general term.
It depends what you mean though, and if that amp is 2 ohm stable (or 1 ohm)
If 2 ohm stable, you can get 4x 4 ohm drivers (any combination) and wire 2 drivers into a 2 ohm load for each channel.
For components, it depends on the the crossover's ohm load (I've only used one cheap pair of cadence components and run an electronic crossover (separate setups) so I have no idea how those boxes that come with comp sets work). If the box is wired for a 4 ohm load, then you can easily run 4 comp sets safely (assuming the amp is 2 ohm stable on each channel)
Are you planning on running tweeters? electronic crossover? 2-ways?
"15 mojo" is also very general. (well kinda) if it's the Memphis 15-M3MOJO15 which is 1k rms, then that 600w rms output (claimed output of that thread), then it should power it fine (I do not know what that sub can actually take as far as clean RMS power, I'm just going by the ratings. if it can take 1200-1500 rms, then no, I would not use a 600w rms output amplifier for that sub.
team graham
Old 07-11-2013, 02:25 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Originally Posted by BallzFast View Post
Doing comps?
With a 55 ampere alternator and 3 cylinder 55 horse power motor?
Also, why is this in the enclosure design section, lol...
team graham
Old 07-11-2013, 02:34 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
who is to say this person isn't doing something like the DDbeast? it had a big ea alt,ran 16v system,had batcap 8400(i think), 2 powerbass 5k amps and 2 dd9515f's doing 157-158 on music and burped a 159.7.
My game is legit,
Old 07-11-2013, 02:38 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Well considering the 15" mojo and 600w rms sub amp, I don't think that's going to happen
team graham
Old 07-11-2013, 02:39 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
^ Just gotta raise idle to like 1500 so the engine doesn't die rofl.
Current Build:
#60sHereIcome
Old 07-11-2013, 02:41 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
gotta start somewhere
My game is legit,
Demo on the Geo Metro Punisher !!! fecupe2001 Car Audio Videos 11 11-07-2012 11:55 PM
Geo Metro owns all.. Vid TwistedMinds Off Topic Chat 18 10-14-2010 06:16 PM
1996 Geo Metro :) PlugItIn Miscellaneous Stuff For Sale 2 01-04-2010 10:27 PM
My 91 Geo metro with a Fi Q 12" EricM9104 Build Logs 19 10-14-2009 04:46 AM
