Make more accurate boxes with Sketchup - Car Audio Classifieds!
Old 07-16-2013, 02:31 PM
GPCustoms's Avatar
0/11 ssssss661
Default Make more accurate boxes with Sketchup
Couple of tips I wanted to share with everyone who might not know about this.
I'm sure many of you know about the "entity info" tab on Sketchup. What I'm going to show you is a couple of ways you can use it to accrately calculate the internal volume of your box overall, and figure out how much airspace is displaced by bracing.
I've found it especially useful in finding the volume of oddly shaped enclosures and curvy bracing. The less math you have to do, the better, right?
So for starters, you're going to need your completed enclosure (minus the top) in a group. I find it easier to group each piece of the box individually as i'm designing, but more on that later.
Select your entire enclosure, right click on it, then click on "make group". Should look something like this:
Next, draw an outline of the inside of your enclosure from the top (or bottom), Like this:
Then, use the push/pull tool to bring it down. Make sure you fill all the crevices. After you've done that, triple click the shape you just made, right click, select "make group".
After that, go to Window> Model info and you should come to a screen like this. Click on units, then click the drop down menu pictured, and select engineering. Then close that window.
Right click on the shape you just made and select entity info.
This window should pop up somewhere on your screen giving you all the stats about the shape you just made, INCLUDING the volume in cubic feet.
Then you can do the same thing to your bracing (so long as it's in a group/component)
Team Showtime Car Audio
The Following 2 Users Say Thank You to GPCustoms For This Useful Post:
k3n12ock (07-16-2013), soFat! (11-07-2016)
Old 07-16-2013, 02:43 PM
GPCustoms's Avatar
0/11 ssssss661
45's get a little bit trickier though. Since entity info only measures the volume of the shape that in a given group, the previous method won't be accurate.
The piece of wood alone on this 45 would take up this amount of space if it were just sitting somewhere flat inside the box.
But since it's at a 45 degree angle against a floor and a wall, the airspace behind it is not part of the enclosure's volume. So make a triangle the same size as your 45 like this, and the numbers will be accurate.
666WMD (07-16-2013), k3n12ock (07-16-2013)
Old 07-16-2013, 03:28 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Thanks for pointing that out. I was just selecting the surface area and multiplying by the height. :-P
Old 07-16-2013, 03:37 PM
GPCustoms's Avatar
0/11 ssssss661
Just realized I included the "port" in the volume of the front chamber.
Don't do that lol.
Old 07-16-2013, 03:40 PM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
that box is gunna flex like crazy. otherwise seems like some good hints!
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 07-16-2013, 03:47 PM
GPCustoms's Avatar
0/11 ssssss661
The dude has 5 sheets of 1 1/8" MDF, and not a penny more to spend for bracing or extra wood lol. Might toss around some more idears with bracing, but that's a story for another time.
Old 07-16-2013, 04:21 PM
DoucheMiller
0/11 sssss3720
the port all is going to flex like nuts. brace it more. redesign the rear chamber so it attaches to it.... will help everything. haha
Old 07-16-2013, 04:27 PM
GPCustoms's Avatar
0/11 ssssss661
That's double layered. I'll look into more bracing though.
Old 07-16-2013, 04:32 PM
DoucheMiller
0/11 sssss3720
that's only 2.25" thick. looks to be about what 33" tall? from experience... it will flap in the wind, move close to an inch each way in the center. it will require a brace. also when designing what looks to be a wall.... you can use the actual vehical to brace the enclosure. attach your shell to the car then build around your shell. ect. can reduce ALOT of your internal bracing by using the outside of the box.
blah blah ect ect...
The Following User Says Thank You to Anton Miller For This Useful Post:
soFat! (11-07-2016)
google sketchup ? JAYARE2007MAG General Car Audio Discussion & Questions 3 12-11-2012 09:27 AM
Sketchup help mcmuffin Enclosure Discussion & Design Construction Help 12 04-13-2012 03:31 PM
Google Sketchup help Patrick Simmons Enclosure Discussion & Design Construction Help 5 07-16-2009 01:40 PM
Sketchup Tutorial caps Tutorials & Quick References 2 01-17-2009 01:03 PM
How to make 45 Degree Inserts (Vented boxes) wasted ink Tutorials & Quick References 2 11-27-2008 02:41 PM
