Single Zv.3 12" box design. need advice - Car Audio Classifieds!
Old 07-17-2013, 07:50 PM
0/11 ssssssss5
Default Single Zv.3 12" box design. need advice
I'm new to the forum and never made a subwoofer box. I been on and off working on box designs for my sub but want to start building soon.I am Going to run this of a clean 2k. Need something with good efficiency because all i have is a XS D1200 upfront with big 3, I have not decided on amp, most likely a Soundqubed 2200.1 any suggestions?
Here are some pics of my design. Shooting for 1.75ft^3 @ 33 Hz. Any Advice would be appreciated, Thanks
Also how much space should the motor be cleared by from the port length? My motor depth on my sub is 8.75" and the Box is 9.25" depth. Is .5" enough clearance? Thanks again
Old 07-17-2013, 07:56 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
that is alot like my box i have. mine is 32.5Wx16Hx16D with the L port 4W with first part 11.25L and second part 18.5L. sub area is double layer.
My game is legit,
Old 07-17-2013, 08:28 PM
0/11 ssssssss5
Thanks for the dimensions on your box. ill keep in consideration while finishing up mine
Old 07-29-2013, 03:28 AM
dugjt88's Avatar
0/11 ssssss689
Does your sub have a vented pole piece? If so you'll probably need more clearance than the .5" you've got. Most recommend at least a couple inches. If its just a solid slug/mag go ahead should be fine.
Need a box design for single SA-8 v.2 d2 Boomintahoe Enclosure Discussion & Design Construction Help 23 03-19-2013 05:26 PM
Advice on box design HazeGrey75 (DC) 2 02-26-2012 11:23 PM
Single 15 Box design? xpd442 Enclosure Discussion & Design Construction Help 7 03-21-2011 11:49 PM
Need box design/advice/BOTH EclipseChris Enclosure Discussion & Design Construction Help 1 02-03-2011 08:36 PM
Need Advice for box design and specs in Quad Cab Ram with 1 18" RD Heavyweight GP Drock040687 Enclosure Discussion & Design Construction Help 14 10-23-2009 11:35 PM
