Need design for 2 10-SAs - Car Audio Classifieds!
Old 07-18-2013, 10:57 AM
Burbarry's Avatar
Can you hear me now?
0/11 ssssss898
Default Need design for 2 10-SAs
Im going to down grade to 2 10-SAs dual 4s was running 3 and blew apart my box 3 times now. Going to keep running on a SAZ-1500v1 for a while. Going to do firing forward like I was with the 3 subs in the trunk of a chrysler 300.
Sent from inside the shark tank!
Chrysler 300 on 24" Menzari's
Alpine 9887 Sundown SAZ-1500 3-10" SAs Walled off
Old 07-18-2013, 11:09 AM
Mr.G6's Avatar
0/11 sssss4614
thats just shitty craftsmanship 100% no need to drop a woofer just bc your box is shitty
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
tylork92 (07-18-2013)
Old 07-18-2013, 11:55 AM
Burbarry's Avatar
0/11 ssssss898
Box built with with glue first time, glue and screws second time, glue screws and wooden dowels to support flexing of the box. Been doing this since the 90s man pretty sure I know how to build a box. Just a lot more pressure in the short box. See design
Old 07-18-2013, 12:10 PM
0/11 ssssss614
Theres no way that box should be falling apart. Use titebond 1 5/8" screws birch wood and 3/4 to 1" dowels if you dont like that slap a 2x4 in there should be a brickhouse then. No nee to get rid of he 3rd sub
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
02 s10 147.3 (louder now) on the dash
Old 07-18-2013, 12:13 PM
0/11 ssssss614
Not trying to be an ass but if you have been doing this for 20 years i font know why you would have built the first box just with glue.... You have 3 10s on close to 2000 watts dosent surprise me at all the first one fell apart.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
Old 07-18-2013, 12:16 PM
Burbarry's Avatar
0/11 ssssss898
Well getting rid of third sub for now. Trying to drop down and run more efficient. 1 of the 10s will be going up for sale soon. This is a daily driver car and probably sees a lot more play time then most as my drive to and from work is about an hour each way.
Old 07-18-2013, 12:18 PM
0/11 ssssss614
I would do 3cu 1 6in aero of u need dims and all that i can get you that after work if u need me to.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
Old 07-18-2013, 12:24 PM
Burbarry's Avatar
0/11 ssssss898
I always use the titebond but after these box failures Ive been loosing faith in it.
Old 07-18-2013, 12:32 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
silly people. you dont need screws on enclosures. for years its been known just to back the screws out of the box then fill with wood filler.
My guess is your glue joints are poop and the cuts are off in size
Old 07-18-2013, 12:34 PM
0/11 ssssss614
Guess im silly i always use screws..
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
SAS Euphonic one passive 2 way crossover & one 4" mid $25 shipped iamsonic Component & Coaxial Speakers 1 10-25-2013 11:36 AM
WTB a Sundown Amp for pair of SAs burzendowski Wanting to Buy (WTB) 3 02-06-2013 07:11 PM
sas bazooka with a sa-8 or other? rocksolid84 General Car Audio Discussion & Questions 14 05-06-2012 02:53 AM
4 SAs in 240sx KTMrida4life Enclosure Discussion & Design Construction Help 16 01-15-2012 06:43 AM
SPL coil SAs RidnClean (Sundown Audio) 9 05-07-2011 06:53 PM
