6th order, too much rear port? - Car Audio Classifieds!
Old 07-20-2013, 06:19 PM
0/11 ssssss463
Default 6th order, too much rear port?
I've read that 5-8 sqin per cuft is nominal, but is 9.2 too much?
Tantric HDD's 15" on a M3b @1ohm(3k?)
Old 07-20-2013, 06:42 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
if i remeber correct, to big will make it peaky/less bandwidth... how big is to big, im unsure
my 6th orders i shoot for 7 ish depending
Old 08-02-2013, 07:46 PM
0/11 ssssss463
*reduced rear port to 63 sqin, and IT'S HAPPENING!
Waiting on the HDD's!!
Old 08-02-2013, 08:04 PM
0/11 sssss1417
too big will cause subs to unload.
Old 08-02-2013, 08:05 PM
0/11 sssss1417
ps i would tune the front a little higher. just my opinion though.
Old 08-02-2013, 08:06 PM
0/11 sssss1417
usually 1 octave away. around 56hz
Old 08-02-2013, 08:16 PM
0/11 ssssss463
intended to tune higher. however, the hole in the bed was already cut from a previuos build and dont want to go bigger. tuning higher would require a shorter port (with current sqin), which would not extend into the cab of the truck. bigger port would work, but i'd have to recut and seal the bed again (PITA).
As far as unloading, I did a LOT of reading while planning and found that 5-8 sqin of port per cu ft of air is optimal for the rear chamber. I'm at 7.85 per.
Why would this unload?
6th order bp port area, help! 321slapinbass Enclosure Discussion & Design Construction Help 4 08-28-2012 12:28 PM
Quasi 6th Order Bandpass port orientation... quagmire Enclosure Discussion & Design Construction Help 10 06-07-2012 10:23 PM
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
Port through rear deck, 4th order? Jh8909 Enclosure Discussion & Design Construction Help 11 02-06-2010 12:10 AM
