band pass (2) 15s - tired of designs - Car Audio Classifieds!
Old 07-22-2013, 01:03 AM
germandark's Avatar
My name is Dylan.
0/11 ssssss130
Default band pass (2) 15s - tired of designs
here it is, going for it. have a cutlist, wood, glue, clamps, few screws, threaded rod, and some 2x4s.
click to make larger. Please critique.
on to photos....
for illustrative purposes by boringwhiteranger, on Flickr
for illustrative purposes2 by boringwhiteranger, on Flickr
for illustrative purposes3 by boringwhiteranger, on Flickr
CA: bunkerking09, jaredspl; CACO:- gentlejax2, 727Designs, g6ryder, Mike Stuber; FLSPL: Moore941, mikeyraw, Sonny123
Old 07-22-2013, 01:08 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
will this be a blowthrough?
Old 07-22-2013, 01:47 AM
germandark's Avatar
My name is Dylan.
0/11 ssssss130
yes it will be into a 2004 Ranger XL (standard cab)
subs are DC Lvl4
Old 07-22-2013, 02:57 AM
0/11 ssss31258
you'll want to give your blow through a lot of thought and actually cut it before you build your box.
the blow through I ended up with on the ranger I cut was 33" x 11". your ports are wider than that. you need to know what you are cutting before you build.
Also, on a full width port like that, don't consider it two ports. for it to be two ports, there would need to be more than a divider separating them.
lastly, it would be best if you made the port(s) L shaped {in then up} so they do not receive direct airflow from the woofers.
germandark (07-22-2013)
Band pass 1LOUDYUKON Enclosure Discussion & Design Construction Help 9 06-16-2013 06:48 AM
Seat Terra Band Pass vehicle muriloalvares Miscellaneous Stuff For Sale 0 04-01-2013 04:45 PM
Tantric SHD 15, DD M3b, 6th order band pass Eocuph Car Audio Videos 16 03-28-2013 10:38 AM
4th order band pass Jtasaro Miscellaneous Build Logs 0 05-18-2012 09:51 AM
How do you band pass in active set up? SKDooley General Car Audio Discussion & Questions 4 02-14-2012 02:58 AM
