Smallest sealed box I can use for my sub. Please help - Car Audio Classifieds!
Old 07-23-2013, 02:56 PM
0/11 sssssss86
Default Smallest sealed box I can use for my sub. Please help
Whats the smallest recommended sealed box size for this sub?
18" 05 re audio xxx 18
Fs = 29hz
Qms = 5.09
Qes = 0.64
Qts = 0.59
Vas = 244.2
Trying to squeeze 6 into a suburban, lol. Need to be sure it's even possible.
Old 07-23-2013, 03:04 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
3.3 to 4 cubes per sealed
Although many will suggest ported
Old 07-23-2013, 03:10 PM
0/11 sssssss86
For real?!! that's awesome. My box with 4 18's is 22 cubic feet right now and i have space to simply cut 2 more holes in the box but, I figured I'd need to rebuild with a larger enclosure by adding 2 more 18's.
Old 07-23-2013, 03:12 PM
0/11 sssssss86
I don't want ported. It sounds like poop.
Old 07-23-2013, 03:17 PM
Authorized Vendor
0/11 ssss14115
Audio Savings | (2) RE AUDIO XXX18D2 XXX 18" SUBWOOFERS+SEALED SUB BOX
Old 07-23-2013, 03:19 PM
Authorized Vendor
0/11 ssss14115
Not if to the right size and correct specs
graham (07-23-2013)
Old 07-23-2013, 03:20 PM
0/11 sssssss86
Mine are the older 05 model. Not the new ones.
Old 07-23-2013, 03:24 PM
Authorized Vendor
0/11 ssss14115
This is the old manual, same specs
http://www.google.com/url?sa=t&sourc...pt3SPc0p8e7afg
audioanarchist (07-23-2013)
Old 07-23-2013, 03:25 PM
tacomaguy1's Avatar
0/11 sssss4401
than you're not doing it right
05 xxx's are some of the best sounding subs I've used
box specs? Pics?
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 07-23-2013, 03:27 PM
0/11 sssssss86
Originally Posted by Jeffhulbert50 View Post
Awesome find, thank you so much!
Smallest box possible 18" hdc3 Bubba906 General Car Audio Discussion & Questions 14 11-22-2011 07:59 PM
smallest box for solo x 18 C-LOS Enclosure Discussion & Design Construction Help 21 09-02-2011 09:55 PM
Smallest ported box for (2) 12" NS edouble101 (Sundown Audio) 3 03-13-2011 12:13 PM
SMALLEST box size for (2) sa15s k3n12ock (Sundown Audio) 19 02-07-2011 10:42 PM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 04:17 PM
