Enclosure for two SA-15's - Car Audio Classifieds!
Old 07-24-2013, 05:04 PM
ControlFreak's Avatar
0/11 ssssss457
Default Enclosure for two SA-15's
The first picture shows the 3D view of the box. This is a 7.41 ft^3 common chamber, single slotted port box with the Torres calcs below as well. This is to be for two SA-15's. Opinions? This is my first attempt at a design so constructive criticism is appreciated.
Old 07-24-2013, 07:19 PM
0/11 ssssss339
That will be a total pain to build. What's it going in? If an suv subs up port back.
Sent from my SGH-T999 using Tapatalk 2
Old 07-24-2013, 09:53 PM
0/11 ssssss457
It's going in a 2008 dodge ram 2500 quad cab in the back seat. Not replacing the seat, but flipping it up.
Old 07-27-2013, 10:34 AM
0/11 sssssss40
is that 7.41 gross or net? if net, you could stand to shrink it to ~6 cu ft and make a more simple to build enclosure. what is the space you have available? seems a rather odd shape
Old 07-27-2013, 02:32 PM
0/11 ssssss457
It is an odd shape. It's going in the back seat of my truck. I figured if I had to look at it, I I'd rather not just look at a box but something a little more stylish.
The Following User Says Thank You to ControlFreak For This Useful Post:
iamsonic (07-27-2013)
Old 07-27-2013, 02:45 PM
0/11 ssss31258
looks good. double check everything and then build it.
note: other designs.. such as down firing the subs... with the port firing to the passenger side.. could load better into your truck and make it a monster which sounds and feels about four times as loud.
sgacustoms (07-27-2013)
Old 07-27-2013, 03:58 PM
0/11 sssssss40
i can dig it.
Old 07-27-2013, 04:00 PM
0/11 ssssss457
I've been told my port area is too small. Sonic, thanks for the heads up. I like the idea. When you say down firing, you mean down at the floor of the cab right?
Old 07-27-2013, 04:04 PM
0/11 sssssss40
what is your port area? youll want to get it around 80-100 sq inches or so.
and yes unless im also mis interpreting what hes saying then down firing is facing the subs at the floor of the truck
Old 07-27-2013, 04:40 PM
0/11 ssssss457
This drawing is showing only 28 square inches. I've since changed the design so the port is 90 square inches and I added 1.5" of height at the base to account for the port displacement inside the box.
professional enclosure for two 15's - trailblazer or other suv's kowboy Wiring, Electrical & Other Installation Equipment 15 07-21-2013 08:44 AM
Level 3 15's enclosure dadydolas (DC) 5 03-28-2010 09:44 PM
Enclosure Build: Scapelli's Dual-15's Pioneer~Saturn Build Logs 88 03-06-2010 01:23 PM
Enclosure Build: Rob's dual 15's Pioneer~Saturn Build Logs 35 01-31-2010 10:49 PM
For 6 15's what enclosure would be louder lamchop_8 Enclosure Discussion & Design Construction Help 217 09-11-2009 07:21 PM
