Aero Ports? - Car Audio Classifieds!
Old 07-27-2013, 11:30 PM
fireitup's Avatar
0/11 ssssss616
Feedback Score: 31 reviews
Default Aero Ports?
I see people using some type of green pvc looking pipe for ports. My question is where can it be bought and is it the cheapest option? Also where can the flares for these be bought as well.
Old 07-27-2013, 11:32 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
check with local largescale plumbing supplies or installers. They aren't normal consumer items hence why they aren't found at HD or lowes.
Current Build:
#60sHereIcome
Old 07-27-2013, 11:37 PM
AlwaysLearning's Avatar
CACO Late Nite Tip
0/11 ssssss472
You talking about the thin walled light green stuff? Its drainage pipe, can be found at lowes/ probably home depot. Its cheaper than the regular sch 40 or 80 pvc iirc
2004 Jeep GC Laredo WJ
1 15" Tantric Sounds HDD 15 ~4ish net @ 30hz
American Bass 500.1
SINTORMAN's Avatar
0/11 sssss4907
link? I have never seen the green pvc at hd.
Current Build:
#60sHereIcome
Old 07-27-2013, 11:38 PM
fireitup's Avatar
0/11 ssssss616
This links are good!
Old 07-27-2013, 11:43 PM
CACO Late Nite Tip
0/11 ssssss472
Mobile link Lowe's Home Improvement
Regular Shop Charlotte Pipe 4-in x 10-ft Solid PVC Sewer Drain Pipe at Lowes.com
Havent checked home depot but I almost bought some at lowes
American Bass 500.1
Old 07-27-2013, 11:44 PM
SINTORMAN's Avatar
0/11 sssss4907
I am pretty sure he is referring to larger than 4" stuff. You can get normal pvc in that size.
Current Build:
#60sHereIcome
Old 07-27-2013, 11:46 PM
CACO Late Nite Tip
0/11 ssssss472
They have 6" too, if he needs bigger he probly wont find it there
Old 07-28-2013, 12:50 AM
Boomsday's Avatar
0/11 sssss1929
Feedback Score: 25 reviews
Lowe's has 6x17 in the green for like $18
any bigger and get sono tubes for cheap and spiral fittings for cheap then make ur own
Aero ports ATOMICMERC General Car Audio Discussion & Questions 11 03-04-2012 04:29 PM
aero ports hdman87 General Car Audio Discussion & Questions 12 07-13-2010 11:46 PM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 03:09 PM
aero ports obrien202 General Car Audio Discussion & Questions 4 05-21-2009 08:43 PM
Pvc Ports Vs Aero Ports - Help Bushj311 General Car Audio Discussion & Questions 24 01-07-2009 08:37 PM
