Tantric MD12 Box Help - Car Audio Classifieds!
Old 07-29-2013, 12:09 PM
0/11 sssss1056
Default Tantric MD12 Box Help
I just picked up an MD12 d2, which I will be running around 1K to. I have a Sonata so it will be going in the trunk.
How do you think this would work
Width - 28
Height - 14
Depth - 14
Port 12.H x 14L x 2.5W
This should give me around 1.86cf3 @ 36hz with around 17sq of port per cf
Think that will work or would I be better to go with 2 4inch aeros?
I listen to a lot of OG rap and some heavier metal
Tantric Sounds MD12 D2 Jayzbent 12" Subwoofers 5 06-26-2013 09:57 AM
Tantric HD 10's box? jheist1991 Enclosure Discussion & Design Construction Help 0 06-02-2013 07:57 AM
which tantric subs would work best in this box? fyerbyrd22 Enclosure Discussion & Design Construction Help 14 05-30-2013 10:09 AM
need box design for 2 12 tantric hd Spena Enclosure Discussion & Design Construction Help 0 01-28-2013 07:28 PM
Tantric MD12. "T-Fade edition" TaylorFade 12" Subwoofers 9 11-15-2012 07:50 AM
