6th order ideas? - Car Audio Classifieds!
Old 07-29-2013, 03:16 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
Default 6th order ideas?
I have 71in Deep 34in High and 43in Wide to work with. I need help brainstorming some 6th order ideas
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 07-29-2013, 05:01 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Pay mike to build it. /thread
Sent from my PC36100 using Tapatalk 2
Old 07-29-2013, 05:18 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
I'm think 8 15s series tuned 4.5 per woofer rear. Just need help on the front chamber and port area. Also there will only be about 14in between the baffles
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 07-29-2013, 05:43 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
i wouldn't do that. you'll have no front chamber space.
i'd do 6 15's w/ 3 cubes per rear and you'll have around 3-3.5 front depending on how thick your walls are.
you using those tantrics in your sig?
Old 07-29-2013, 05:58 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Yeah fr now. The only issue is my width. I was also thinking 4 15s forward firing 6th order
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 07-29-2013, 06:01 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
The demensions I gave you are about 1.5ft from the loading wall. Meaning that's the space from the end of the baffle to the loading wall
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 07-29-2013, 09:39 PM
Veteran Member
0/11 sssss3026
still not following you.
are they all internal measurements? top,bottom, and sides external front back internal?
Old 07-30-2013, 07:12 AM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Dimensions are internal. I currently have a 4th order, that's what I took measurements about a foot back from the loading wall.
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 07-30-2013, 03:19 PM
0/11 sssss5305
what is wrong with your 4th order?
Team Never Happy
Old 07-30-2013, 05:58 PM
0/11 ssssss995
Team Never Happy
And Team Never Answer my Phone
TEAM D.O.A
Soundigital Rep
6th order. Ideas and thoughts please! A.Smo Enclosure Discussion & Design Construction Help 5 11-13-2012 02:33 PM
SA8v2 4th order/6th order/Vented melverc Enclosure Discussion & Design Construction Help 0 10-07-2012 10:44 AM
4th or 6th order ideas windowtinter Enclosure Discussion & Design Construction Help 8 09-16-2011 03:53 PM
