Can I fit 4 15's - Car Audio Classifieds!
Old 08-01-2013, 05:26 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Default Can I fit 4 15's
New Sundown basket, outer dim=15.51". Plane is 44x29. Even a from of staggering like up, down, up, down....can I fit/do 4 15's? Math is escaping me right now and I'm too stupid for sketchup.
Old 08-01-2013, 05:30 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Yes, the 29 will make them slightly staggered to make up for the 2..02 missing
Old 08-01-2013, 05:34 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Anyway you can do me a solid and just sketch that up for me so I can see it visually? I really appreciate the help
Old 08-01-2013, 05:41 AM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
yes, it will fit. very tight squeeze, something like this.
edit: this is rough, you can move them a bit around. i used 15.51" exact in this.
Old 08-01-2013, 05:42 AM
Authorized Vendor
0/11 ssss14115
On my way to work or I would so ill try to explain... 2 subs = 31.02" so it'll fit on the 44 plane mo problem, but not the 29 unless its staggered... so basically if u set the 4 15s on the ground in a square, Ud move two backwards until u get ththe9 plane to fit, then check to assure the other length measures less then 44
Old 08-01-2013, 05:45 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Thanks guys, I really appreciate it
Old 08-01-2013, 12:13 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
Does that plane need a port or is that just the baffle without port plane?
Sent from my SGH-M919 using Tapatalk 4 Beta
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 08-01-2013, 04:53 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Without port, it is for a 4th order, trying to see if I can fire everything forward.
dc xl m2 15's, memphis mojo 4k amp new style shocker sigs 15's, kinetic hc2000's SlaminHo6s Car Audio Trader (WTT) 17 09-16-2012 12:21 PM
Could I properly fit two 15's in this? Blake71091 General Car Audio Discussion & Questions 10 04-14-2012 11:21 AM
12 15's dc audio jeep, ryans 4 15's codys 1 18 etc! T3audioNavi Car Audio Videos 7 04-07-2011 04:01 PM
2x custom D1 15's + Dual 15's box w/ 10.5" Alum Flared Aero snb778 15" Subwoofers 13 02-08-2010 02:15 AM
(4) Memphis MOJO 15's reconed with FI parts WTTF for 2 B.A. 15's 18inchjeepin Car Audio Trader (WTT) 6 01-22-2010 04:30 PM
