Port q's - Car Audio Classifieds!
Old 08-16-2009, 08:57 PM
biscuit's Avatar
0/11 ssssss555
Default Port q's
does anyone have any technical explainations for the reason of the difference between round, rectangle and triangle ports? example; i build a 12ft box with 120"^2 of port area and tune it bout 36hz.. if i did a rectangle port just say 3x40 it would need to be 24-26" long... but i used a 12" round port and only need bout 13"length... is there something about a round port that uses the same area but needs less length? any tru infos appreciated... im just looking to expand my knowledge
Old 08-16-2009, 08:59 PM
Lance_aka_64's Avatar
has too many subs
0/11 ssssss462
that sir is a good question.
refs:
from here:teamsubgopoof, splvictim20, SundownAudioNY, goodstuff, Hertz5400LincolnLS, us3, bigjoker
from smd: RollinSoLow, Derrick824, Ray
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
Do what Sonic says, or be a man and punch her in the pussy.
Old 08-16-2009, 09:02 PM
No, I'm not dead
0/11 sssss8128
The 12" round port has less area. 6.9" less to be exact. Still, it shouldn't cut the length in half.
Old 08-16-2009, 09:03 PM
biscuit's Avatar
0/11 ssssss555
also for others reading this who arent mathematically gifted.. 12 round port is also about 120"^2
Old 08-16-2009, 09:10 PM
biscuit's Avatar
0/11 ssssss555
inserted all this info in my box program and thats the info it gave me...
Old 08-16-2009, 09:14 PM
No, I'm not dead
0/11 sssss8128
That's just bizarre. It's always been my experience that to cut the length in half you need a big difference in port area. 6.9 sq in just isn't that big of a difference. Try cutting the square port's area down to 113.1" and see where the length goes. 2.8275" X 40" would give the same area as the 12" round port.
Old 08-16-2009, 09:27 PM
biscuit's Avatar
0/11 ssssss555
yea thats my thought exactly... i tried several shaped ports with different dimensions and all of them but the round were long.... i had a friend do the same on his program and got basically the same results.... soooo confused.....
Old 08-16-2009, 09:31 PM
I get 1" difference in length
Old 08-16-2009, 09:39 PM
No, I'm not dead
0/11 sssss8128
What programs are y'all running?
Old 08-16-2009, 09:43 PM
biscuit's Avatar
0/11 ssssss555
bass box pro 6
Port? gbo559 General Car Audio Discussion & Questions 4 08-03-2009 04:03 PM
port Fosgate1 General Car Audio Discussion & Questions 10 07-05-2009 07:46 AM
port Fosgate1 Enclosure Discussion & Design Construction Help 3 07-02-2009 06:18 PM
Port help please Team3d Enclosure Discussion & Design Construction Help 2 04-07-2009 08:23 PM
