need help designing box for my 2 aq 12's. - Car Audio Classifieds!
Old 08-04-2013, 12:42 AM
06blackgto's Avatar
0/11 sssssss71
Default need help designing box for my 2 aq 12's.
Hey guys. I just bought 2 aq Hdc3 subs. Dual 1's. We tried 1/4 ohm and figured with boxrise my dd2mb would handle it. Well it didn't like 1/4 . So we have them wired up to a 1 ohm load. Slot ported box. It just doesn't sound too strong. The box is a 5 cu. Ft. Box. Anyways.we clamped it today. 60v. On the dig. Multimeter. And 21 on the clamp meterWhich caum out to 1302watts. But the boxrise reading came out to 2.95 ohms. So I believe the box is very inefficient. The volts started out at 13.6 dropping to 12-12.5 v.
I know this dd amp has more in it. I would like to run two 6" aero ports. Can some one who is pretty good draw me up a good efficient box for.my 2 Hdc3. 12's. Thanks. Sorry for the long post.
Or I do have a chance to buy a pair of treo SSX 12's. Dual 2 ohm. Which I can get down to 1/2 ohm to start with.
Old 08-04-2013, 01:39 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
vehicle?
My game is legit,
Old 08-04-2013, 01:44 AM
06blackgto's Avatar
0/11 sssssss71
Dodge ram 1500 extended cab.
Need help designing a box bigjack216 Enclosure Discussion & Design Construction Help 18 08-19-2012 04:17 PM
Need help designing Box for (2)SA-15 02ls1s10 (Sundown Audio) 4 05-24-2012 05:05 PM
need help designing a 8 12 box 9blazer8 Enclosure Discussion & Design Construction Help 4 05-09-2012 10:33 PM
need help designing this box brian84corvette Enclosure Discussion & Design Construction Help 8 09-26-2010 01:50 AM
need help designing a box extremechevyman67 Enclosure Discussion & Design Construction Help 0 03-05-2009 10:06 PM
