Port Area - Car Audio Classifieds!
Old 08-06-2013, 12:47 AM
0/11 ssssss113
Default Port Area
I've been thinking it over, and i don;t understand why the port area is based on the size of the box, instead of the driver displacement?
It seems like there should be larger ports for drivers that move more air, instead of there needing to be more port area for a larger box volume?
I would also like to understan what happens when you leave the recommended range of port area for a particular build. What happens if your port is too big, or too small for the box volume?
Anyone care to explain?
Old 08-06-2013, 12:58 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Port area can be complicated. Depends on if it's a ported box, or bandpass. Or if it's in a car or in a house. Too big of port, you lose some quality, maybe will sound muddy, but the biggest loss is in bandwidth. Too small and you get port noise and decreased output/SPL.
It's really situation dependent. Even with ported boxes, say with my 2 18's. I have 12.3 in^2 per cube port area @ 29 hz. But if I was to go for a SPL it'd be more like 16+ in^2 per cube. So port area can vary tremendously. Some aero boxes I've done only have like 4-5 in^2 per cube and performed very well.
When there is more air in the box for the woofer to move, there is more air coming out of the box...think of it that way and that's why you have to have a bigger port.
Also, as you tune lower, your air speed in the port will lower as well given all other variables stay the same.
Old 08-06-2013, 07:33 AM
vince79vette's Avatar
0/11 sssss2011
Whats ur range u do for aeros. And would u count round port as a aero as in sonic tubes. I have always just calculated how much area i need and used a sonic tube to get that area
Old 08-06-2013, 08:39 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
i prefer tubes for saving space but like the added structure and stability u can get w the extra wood from a slot. Like the tuneability of a round port also.
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 08-06-2013, 08:53 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Aeros usually need less port area too as there's no sharp corners or bends usually to get the air in a bind. I use 1/2 the port area needed for a slot when I do aeros. Except in 4th or 6th's.
Old 08-06-2013, 09:02 AM
chrishova's Avatar
Eight 12''s
0/11 ssssss703
Tuned in for this discussion
Sent from my Galaxy
'97 Grand Prix GT 3.8
5 Black Cherries
Eight SA 12''s on a DDz2
Old 08-06-2013, 10:21 AM
Mr.G6's Avatar
0/11 sssss4614
well its sono tube's not sonic tubes lololol
and the general rule for aeros is 6 to 10" per cube..
and yes any round style port is considerd "aero"
a 8" diameter sono tube has like 50.24 sq inches of port
2000 Gmc Sonoma ext cab
Old 08-06-2013, 11:01 AM
AlwaysLearning's Avatar
CACO Late Nite Tip
0/11 ssssss472
Too bad winisd doesnt account for porr area in its response curves :/ and I know I know winisd doesnt mean anythig but its cool to see what changing variables does. It will tell you about air speed in the port tho. I thought it was the lower the tune freq the faster air moves tho right I tuned at 10hz once it was fun
Port area witherman Enclosure Discussion & Design Construction Help 2 10-02-2012 12:58 PM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 10:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 10:52 PM
Port area BigBen Enclosure Discussion & Design Construction Help 12 03-21-2011 06:46 PM
