Attn: Experienced Designers and Builders - Car Audio Classifieds!
Old 08-16-2013, 04:03 AM
0/11 ssssss384
Default Attn: Experienced Designers and Builders
Ok, heres the deal. I have a customer at my shop with all the gusto in the world for car audio but not a lot of technical info in his background. He decided to go ahead and design and build an enclosure for his vehicle, a 1985 Monte SS. In the trunk he wanted to put 2 Digital Designs 9518s. His box dimensions (inner) are 12h x 41w x 18.75d. The port is an external slot port with dimensions of 41w x 8h x 14d. Now from what I understand, and again, this is according to the customer, in preliminary testing, this box sounds amazing. I'm not 100% certain that it wont do work, but to me it seems like its Big Trouble in Little China. Do any of you think this enclosure has a shot at working without annihilation of his subs? Fyi, they'll be on an m4a with healthy electrical...
Old 08-16-2013, 04:09 AM
truebassjunkie777's Avatar
Team Bad Intentions
0/11 ssssss632
Subs facing up and ported into the car?
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 08-16-2013, 04:23 AM
0/11 ssssss384
Yes sir
Old 08-16-2013, 05:31 AM
Team Bad Intentions
0/11 ssssss632
The only problem I forsee is the subs not having enough room to breath
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 08-16-2013, 05:36 AM
Team Bad Intentions
0/11 ssssss632
That comes to 4.14 cubes gross. You need alot more room then that to be honest. Enless my calculations are off
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 08-16-2013, 08:31 AM
0/11 ssssss384
Exactly what I tried to tell him. A touch over four cubes for 2 18's is laughable but 4 cubes with 328 sq in of port is ludicrous.
Old 08-16-2013, 08:51 AM
SPL Distribution Owner
0/11 sssss2983
sounds retarded to me...
No, it IS retarded.
Unless he likes 45hz+ music only, he needs only 1 sub in that box and an 18 is not the right size either.
The Following User Says Thank You to shizzzon For This Useful Post:
truebassjunkie777 (08-16-2013)
Old 08-16-2013, 09:04 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
He'll have better output doing a pair of 15s.
Old 08-16-2013, 09:11 AM
that box is tuned to the higher 80's
Old 08-16-2013, 09:14 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
yea that box isn't going to work.
those inner dimensions are 5.33 before sub displacement. it might work for some 15's, definately no 18's
experienced box builders/designers, HELP!!! hdman87 Enclosure Discussion & Design Construction Help 2 04-05-2013 02:45 PM
Alabama Designers and Builders nicholasmccabe Enclosure Discussion & Design Construction Help 12 02-25-2013 09:17 PM
ATTN: Box Designers! Have a question. brandon_s0854 General Car Audio Discussion & Questions 13 08-07-2012 10:36 AM
Need Help From Experienced No Wall Box Builders Bigpimpin91 Enclosure Discussion & Design Construction Help 26 10-02-2011 06:43 AM
Experienced box builders question Boomintahoe Enclosure Discussion & Design Construction Help 7 10-15-2010 08:48 PM
