Box help 2x memphis m312d4 - Car Audio Classifieds!
Old 08-16-2013, 04:47 PM
0/11 sssssss62
Default Box help 2x memphis m312d4
So I plan on running 2 memphis 12" m312d4 on a Orion 1200d @ 1200 rms
The memphis site recommends 2 subs to have 4 cu ft @ 35hz .. The only design I could find was 4.4 @ 35hz. My question is, are those the absolute best box specs for these subs? I listen to mainly rap and reggae. Also can someone edit the build sheet to 4 cubic ft and 35 hz? That's if thats my best option for these subs and my preferred genre. Thanks
Old 08-16-2013, 04:52 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
that size (4.4 @ 35) is just fine... the specs they gave (memphis) is suggested... bigger box = more efficient on less power but less power handling suspension wise...itll do just fine, and ull have sub displacement so tech, ull be a lil less then 4 cubes net
Old 08-16-2013, 04:59 PM
0/11 sssssss62
Thanks a lot man!!
Old 08-16-2013, 05:12 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Originally Posted by xn0tox View Post
Thanks a lot man!!
He knows everything..
Sent from my PG86100 using Tapatalk 2
Old 08-16-2013, 05:28 PM
0/11 sssssss62
That build sheet is good though right? I seen others that had their own chamber it looked like. This one only has one L port? My old box had two "L"'s also. This is a trunk car with rear seats that do not drop down.. I only have the arm rest open to allow bass in, doesn't do much. Should I try a different type of box? Idk anything though about box types like band pass, 4 order, etc..
Old 08-16-2013, 05:35 PM
Authorized Vendor
0/11 ssss14115
that box will work fine... there just different styles of ported boxes...some have two chambers, each with there own port...some have shared or "common" chambers with on port or two...as long as it meets the compliance (likings) of the woofer being used your good to go
Old 08-16-2013, 05:47 PM
0/11 sssssss62
Thanks so much man.. Tomorrow I get cracking!! I pmed u a couple more questions.. I hope u don't mind.. Thanks a lot!!
Box for 2 memphis m class 12s Team Nemesis-Jared Build Logs 1 12-09-2012 12:18 AM
box help needed for memphis pr-s4v2 jeremy21291 Enclosure Discussion & Design Construction Help 0 11-29-2012 09:31 PM
memphis mojo box.. wildcatlove General Car Audio Discussion & Questions 0 01-09-2012 06:49 PM
