XFL 12s 6th order. - Car Audio Classifieds!
Old 08-19-2013, 02:22 AM
0/11 ssssss103
Default XFL 12s 6th order.
So i've just started messing with sketchup and started thinking about some different designs with my available dimensions which are about 32"Wx28Dx15H. id say about 32D if Height is down to 13.5 or 14.
i have never tried tuning a 6th order or even know if these subs will work well in them. What i did on sketchup was just a practice using the program trying to design a clam shell type set up and it kinda became a 6th order but dimensions, ports and tuning is not right but just an idea.
Again, this is just a rough design just messing with the program so any suggestions on if these subs work well in this kind of box or not and some help with a design. this is in a 2008 impala and will be sealed from the trunk.
lol btw this is 70 hz into 110hz for teh tuning
Old 08-19-2013, 02:42 AM
Infinitelybaffled's Avatar
0/11 ssssss816
70hz tuning? Is this for midbass?
Inappropriate sig image.
Old 08-19-2013, 02:53 AM
0/11 ssssss103
i didnt do any tuning at the time i was just messing around on sketch up for the first time and started thinking about a "clamshell" design and it kinda came to this but im really trying to find out if those subs would even do well in a box like this (or maybe a 4th order) and what should tuning be like on such.
Old 08-19-2013, 03:16 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
25/50
30/65
Old 08-19-2013, 03:17 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
then you have to remember on the rear section port area will be considerably lower.... usually half at times.
Old 08-19-2013, 03:23 AM
0/11 ssssss103
Most 6th orders i seen were that way (front port much bigger). The problem i see with doing this is getting enough cubes for each sub and on that particular mock up of a box in my first post, front and back chamber are about same size.
Old 08-22-2013, 08:38 AM
0/11 ssssss103
so did a lot more reading on how to design 6th orders and punched some stuff in winisd and this is what i come up with.
Purple-6th order idea
Red-Current ported box
How does this seem to look for a 6th order? does that seem about right or no? this would be sealed off from trunk in 2008 impala.
Old 08-24-2013, 11:10 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
From the dimensions you posted up you have about 6.31 cubes net before sub and port displacement, to me that is not near enough for a 6th order since generally you want 1:2 ratio. I know my 6th order for 2 atomic apx 12's is 4 cubes net rear and 8 cubes net front after all displacements. Also from experience with American bass subs they usually like an enclosure on the larger side. You might want to go with a standard ported enclosure or possibly a 4th if they are 4th friendly.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 08-24-2013, 11:23 AM
Mr.G6's Avatar
0/11 sssss4614
xfls are very 4th order friendly.. look at randen's (i think its his name) with the 12 15s and a buncha others too
i also 2nd the motion that you aint got enough room for a proper 6th order..
youd prolly still want 3.5 4 cubes sealed and 8 ported or so
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
1loudmonte (08-24-2013)
Old 08-24-2013, 01:48 PM
0/11 ssssss103
I was thinking there wasn't enough room but I wanted some confirmation. Ima going to do a 4th design and see
2 10s 6th order vs 2 12s 4th. Ringspun09 General Car Audio Discussion & Questions 1 02-28-2013 11:55 AM
2 SA-12s 6th order BP burzendowski (Sundown Audio) 33 11-26-2012 04:51 AM
SA8v2 4th order/6th order/Vented melverc Enclosure Discussion & Design Construction Help 0 10-07-2012 10:44 AM
6th Order for 2 Nightshade 12s tprice07 Enclosure Discussion & Design Construction Help 2 07-30-2011 01:04 PM
