Unloading BAD - Car Audio Classifieds!
Old 08-22-2013, 12:42 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Default Unloading BAD
So I built this box 2 weeks ago for a friend. Drove to IL from NC to meet him (hes an xbox friend Ive known for a few years) and built it while I was there. 2 Zv3 18s wired to 1/2 ohm on a lanzar opti 2k or a sundown 3k.
Box specs are 8.9 cubic feet (after port, subs, wood, 45s, errthang) with 15sq inches of port per cube, port is 30" x 4.5" x 25" long. Tuned to 34.
Got it playing and it wont play anything below 45. Unloads BAD. Makes a terrible noise.
I assume the port mouth is too close to the subs. How can they fix this? Im not there anymore to work on it, but I want them to retain this box but just modify it somehow because I built the shit out of it. Braced all to hell and back, rounded port, 45s.. flush mount.. Any ideas? I have a few but want to hear others first
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 08-22-2013, 12:51 AM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
where is the port opening located
inside the box?
edit: aaaah i see it. only way to "save" the box would be to extend the port down the back of the box more...
SHABAM
Old 08-22-2013, 01:16 AM
0/11 sssss2271
inside the box?
Thats my idea. I figured out if they made the port "tunnel" come down another 11", it would leave about 6" at the bottom of the box at the new port opening (theres a 45 there as well) and it would change the specs to this
8.5 cubic feet
30hz tuning
15.7 sq inches of port per cube
I think it will work alot better than how it is now. That will give them something to load off. It would only play from 45+, and peaking at around 48-50.. it was loud AF though at 48hz probably close to a 49 or 50 sealed up
Old 08-22-2013, 01:42 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
are you sure they are wired correctly? I see nothing wrong with those specs at all, nor the port/box, aside from that maybe a divider between the two subs might help
TeamGG
Team D.O.A.
The Following User Says Thank You to Decaf For This Useful Post:
taylorpro (08-22-2013)
Old 08-22-2013, 02:56 AM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
firing up in a suv i assume? has he tryed standing the box up and firing it back?
Old 08-22-2013, 06:11 AM
vince79vette's Avatar
0/11 sssss2011
I actually just made a box just like that and in a suv. It played down to 25 on tones but the 40 was the only real notes u hear weird but i want to say its the port up that hurts it. I had to do the same to max the room for the subs
Old 08-22-2013, 06:52 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
it 100% sounds like you had the subs out of phase. I did this with one of my subs in my 4st four 12s setup and it sounded like absolute crap, and sounded like it was unloading all the time; just like you're describing.
-Youtube Channel
Old 08-22-2013, 07:02 AM
thericanballer's Avatar
0/11 ssssss734
Nice box...I hope it gets figured out because it really looks like you put some work and time into it.
Old 08-22-2013, 11:14 AM
0/11 sssss2271
Anything is possible... I built the subs and wired them up and built the box in like 3 days. I couldve easily wired them wrong, or mixed up a red/black terminal on the sub when I put them on the basket which wouldve confused me when wiring it up.
Old 08-22-2013, 11:20 AM
Mr.G6's Avatar
0/11 sssss4614
i did that on 2 woofers i reconed myself..got the pos and neg mixed up..and i ALMOST thought i wasted 300bux on recones/parts and it was just wired wrong..2 kove Z motors with fi q drop in's
remember positive is always on the left side looking at the woofer negative on the right
2000 Gmc Sonoma ext cab
sub unloading? fyerbyrd22 General Car Audio Discussion & Questions 19 05-08-2013 07:45 PM
Is it bad when.... skartisu General Car Audio Discussion & Questions 4 04-06-2013 01:39 PM
Unloading. Help please. btsteinb General Car Audio Discussion & Questions 33 09-23-2012 02:19 PM
will this have an unloading issue? blk1990gt Enclosure Discussion & Design Construction Help 3 04-24-2012 12:20 PM
Unloading question More spl General Car Audio Discussion & Questions 7 04-13-2012 12:23 PM
