15" HDC3 port question - Car Audio Classifieds!
Old 08-25-2013, 11:36 PM
0/11 ssssss542
Default 15" HDC3 port question
I've started construction on my box, it will be sub up port side with a slot port. I had planned on making it about 17^2 of port per cube, but due to me being absent minded during cutting wood and putting the box together, It came out to 3.6cubes net with 20^2 of port per cube (5 wide by 14.5 tall) and putting tuning at 35hz.
I don't know what the consequences of having too much port area would be, I would assume that I would have unloading issues?
I currently have not put the top on the enclosure yet and have a plan in place if I need to reduce the port area, by using 1/2 birch and making the port smaller and reduce the port area to 18^2 of port. The ultimate goal is to hopefully not scrap this piece of wood and the time I have in it and start over.
Goals are daily music box, nothing needed below 32hz, and not going for crazy numbers. just a decent overall box.
Thanks in advance
port question for a hdc3 12 slowpoke General Car Audio Discussion & Questions 2 09-24-2011 03:45 PM
15" AQ HDC3 question cadillac214 General Car Audio Discussion & Questions 3 10-25-2010 10:50 AM
Kerfed port box for 18" tc9/aq hdc3 hybrid build twisted Build Logs 16 10-01-2010 05:25 PM
Help with port 15" AQ hdc3 alum in 3 cube box djseven Enclosure Discussion & Design Construction Help 7 08-04-2010 03:19 PM
HDC3 18" Question Drewculous General Car Audio Discussion & Questions 16 01-26-2010 03:01 PM
