4th order port area - Car Audio Classifieds!
Old 08-26-2013, 10:43 AM
0/11 sssssss33
Default 4th order port area
I'm wondering how much port area I will need. I'm planning on doing a type of blow threw in my impala threw the rear deck ill be running 3 12" typers on a aq2200 And about 3.25 cu ft sealed and 6 cu ft ported Id like to do 2 6" ports firing threw the 6x9 holes but if I need more port area so be it
Old 08-26-2013, 10:49 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You're at most looking at 110-120 in^2 total. I would do at least 70-80 in^2.
Old 08-26-2013, 10:55 AM
0/11 sssssss33
If I go threw the 6x9 holes ill use areo ports. If I need more area ill cut threw my rear deck and make a rectangle port
Old 08-26-2013, 10:56 AM
0/11 sssssss33
Would I be goo around 90-100 for most range but still kill lows
Old 08-26-2013, 10:57 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
90-100 hz?
Old 08-26-2013, 10:58 AM
0/11 sssssss33
Sq inches of port area sry.
Old 08-26-2013, 10:59 AM
0/11 sssssss33
I think ill tune at about 48-50. I'm most after lows but still wanna be able to play a variety
Old 08-26-2013, 11:48 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
The sealed side has more to do with the lows than the ports.
Old 08-26-2013, 12:15 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
The sealed size res freq needs to match port tuning. Buy a wt3, test different sized sealed enclosures, then build. Don't make the mistake I made and guess
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
The Following User Says Thank You to ddbump For This Useful Post:
2003f150 (08-30-2013)
Old 08-26-2013, 12:53 PM
0/11 sssssss33
I have a termlab. Can I just meter the sealed box and see were it peaks and then tune my port to that
6th order bp port area, help! 321slapinbass Enclosure Discussion & Design Construction Help 4 08-28-2012 12:28 PM
port area 4th order constantprojects Enclosure Discussion & Design Construction Help 28 05-14-2012 11:39 PM
how much port area per cube for a 4th order laextreme5 General Car Audio Discussion & Questions 20 01-19-2012 11:14 PM
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
