Decent center console build help - Car Audio Classifieds!
Old 09-02-2013, 08:46 PM
0/11 sssss4519
Default Decent center console build help
Doing a center console build for a buddy while I am down in Florida for school. He has two Type R 10''s, the newest ones. I was thinking about down firing the subs and rear firing the port. What do you guys thing? 32'' long, 15'' wide, 16.5 high are the dimensions I have to work with. Or should I upfire the subs. Its a 2002 dodge ram crew cab. Must use a slotted port as I do not have time to order aeros
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 09-02-2013, 08:48 PM
0/11 sssss4519
Also tuning as low as possible. I suppose I could use 3'' PVC for ports if I must.
resolve Vas/28.32 =
result of that +1
Old 09-02-2013, 08:52 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
If you down fire them like that it will be easy to loose things in the opening and said things could puncture the speakers easily. You basically have a bandpass design to begin with so why not fully encase the speakers and run a 6th order with one port top of front panel and the other out the top of the rear panel?
Old 09-02-2013, 08:54 PM
0/11 sssss4519
Well the design in the picture will not have the trim going around it. Just a few legs. What do you mean things falling inside the box?
resolve Vas/28.32 =
result of that +1
Old 09-02-2013, 09:34 PM
SPL Farms
0/11 sssss5706
Between the floor and the subs that are firing downward..
Old 09-02-2013, 09:43 PM
0/11 ssss31258
I have a center slot port box with two 10s down firing as my rear center console. {f150 crew}
up firing sucks. down fire or rear fire are the only good way to go.
not sure about the rear fire port.. I like my down firing center port.
I would leave as much side space open as possible. if that becomes a tuned chamber, it can ruin the sound by dictating the sound release.
0/11 sssss4519
I see. Well I suppose that's plausible with about any setup unless you are careful.
resolve Vas/28.32 =
result of that +1
Old 09-02-2013, 09:44 PM
0/11 sssss4519
Thanks sonic. I suppose I can change it up and fire the subs and the port down
resolve Vas/28.32 =
result of that +1
Small build for under the center console. oxsign Build Logs 0 03-09-2013 03:12 PM
subs for center console build please help southautorecon General Car Audio Discussion & Questions 7 02-17-2013 03:37 PM
2001 Mid bass Center Console Build! buttphacekilla Build Logs 19 09-16-2012 07:02 PM
center console build help anyone?? buttphacekilla General Car Audio Discussion & Questions 68 01-20-2012 09:15 PM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 08:22 PM
