bass-box problem - Car Audio Classifieds!
Old 09-04-2013, 05:05 PM
bassman_soundking's Avatar
0/11 sssss2063
Exclamation bass-box problem
Trying to re-do port for lower tuning.
I am using bass-box 6 pro.
I did the start with box way of designing.
I set dimensions as external
I entered front and wall thickness of .75"
A:26.5--B:17.5--C:30.75
Damping is set to no damping material
Vents set to rectangular
Height5.5"
Length15.75
No matter what length I choose for port I cannot get below 32 hz for tuning.
I am shooting for 30 hz.
Can anyone please help me with this?
Box is already built, I just want to lengthen port to tune lower.
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 09-04-2013, 09:06 PM
0/11 sssss2063
This is for a custom TC-5200 15" sub btw.
Sold to: Jonesy
Old 09-04-2013, 09:27 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
32 hz, 25.992
31 hz, 28.200
30 hz, 30.630
29 hz, 33.320
28 hz, 36.301
That's what 12v says for an enclosure that size 6.77 cubes before displ
Old 09-04-2013, 09:32 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Height5.5"
Length15.75
You need to change the port dimensions to get your tuning right... at 16.53.25 with a length of 25 it is exactly 30hz
Old 09-04-2013, 11:59 PM
0/11 sssss2063
Originally Posted by Jeffhulbert50 View Post
32 hz, 25.992
31 hz, 28.200
30 hz, 30.630
29 hz, 33.320
28 hz, 36.301
12v and bass box differ alot, by like 4-5 hz with all those...weird
changing port dimensions will be a problem....16 is the widest I can go as box is only 17.5" wide.
Looks like Ill have to redo port though.
16*3.5 at 25 long is 30hz acc to Bassbox though
RE bow calc says 5.5*16 @41.5" long will yield just over 32 hz
I thought this was just based on math, should always be the same
Sold to: Jonesy
box for american bass hd 15 fyerbyrd22 General Car Audio Discussion & Questions 2 11-03-2012 07:53 PM
is lack of bass an enclosure problem? MERQUE General Car Audio Discussion & Questions 66 03-05-2012 01:52 AM
torres box tuning problem Russellabt General Car Audio Discussion & Questions 2 03-26-2011 03:18 PM
box problem tymoto21 Enclosure Discussion & Design Construction Help 5 10-18-2010 01:58 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 07:46 AM
