need help with box for two dc xl 18's - Car Audio Classifieds!
Old 09-16-2013, 09:16 PM
0/11 ssssss192
Default need help with box for two dc xl 18's
so im having a little trouble figuring out how to figure out my port displacement. the box is 36w x 36d x 21h, so 13.4 before displacements minus the sub disp. it would be 12.9 after subs. I want to tune it to 33-34hz. I was going to do 266^2 in of port. If I type it into 12volt site I get the port has to be between 34 and 37 inches long so how would I figure the port displacement?
Old 09-16-2013, 09:31 PM
0/11 ssssss192
Oh ya and it will be running on a dat 5k @ 2ohms. and im doing 45s hopefully.
Old 09-16-2013, 09:34 PM
0/11 sssss2011
Feedback Score: 61 reviews
So you telling me can figure out displacement of a rectangle sub box but you cannot figure out the displacement of a rectangle port opening?
Old 09-16-2013, 09:43 PM
0/11 ssssss192
if I tune at 35hz the port displacement would be 3.86. so that would leave me with 9 cubes. Would I be choking the subs with only 4.5 each? I can always go taller by a few inches. I just don't want it to go to far over my back seat
Old 09-16-2013, 09:45 PM
0/11 ssssss188
Why so much port? Why not try around 150" of port.
Old 09-16-2013, 09:48 PM
0/11 ssssss192
I'm still trying to figure out all this port stuff. I went to a website (don't remember the name) that figured the minimum port area should be 266 so that's what I was going off of lol. I normally do smaller ports tho.
Old 09-16-2013, 10:05 PM
massivespl's Avatar
0/11 sssss8409
266 is way to much port. try 166sq in
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-16-2013, 10:10 PM
0/11 ssssss192
I was thinking the same thing. i just need to get my cut sheet right before i go building up stuff.
Need a box for 2 18's abrosk927 Enclosure Discussion & Design Construction Help 2 04-18-2013 10:59 AM
Box for 2 18's regizzle Wiring, Electrical & Other Installation Equipment 1 02-25-2013 03:39 PM
Nightshade v2 18's box help ltr450racer690 (Sundown Audio) 11 06-25-2011 11:54 AM
box idea for 18's bobbygilly Enclosure Discussion & Design Construction Help 3 10-25-2010 05:45 PM
sub box for 4 18's kirshland williams General Car Audio Discussion & Questions 31 08-12-2010 06:23 AM
