4th order 1/4wave t-line box for two 8in subs - Car Audio Classifieds!
Old 09-18-2013, 01:57 AM
0/11 ssssss340
Default 4th order 1/4wave t-line box for two 8in subs
im wanting to make the most of two 8in on 600-800watts in a older volvo wagon.
i have a 6th order for a single dd1508 (@4ohms) on bout 150-200watts and it sounds and feeling amazing for the small power and small size of woofer.
so i wanted to make full use my my Crossfire BMF 600d amp to run at 1ohm
so im getting a pair of Massive audio hippo 8
so i thought to do a 4th order box just because i cant find the perimeter t/s of these subs so just to play it safe id tune it to 32-38hz and have the sealed chamber help the sub out.
or i wanted to do a 1/4wave t-line and tune to 35hz or so since the box is very efficient and will get low also.
so my thoughts were why not use both..
do a sealed to get lows and control the cone and do a 1/4wave t-line on top of it to efficiently hit the mid range (meaning 40-60hz lol).
this is just a quick sketch to show you what i mean
no measurements taken
i know will be somewhat big but remember i have a wagon.. i have space!!
so what my question really is....
if i dont have the t/s of the subs what should the tuning be?
and when finding the sqin port size for the 1/4wave t-line would the last tunnel being shared port have to be doubled in size? (width and depth and height?)
Old 09-18-2013, 09:39 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
I'm a novice to t-lines so I could be wrong on this. I believe you would get tuning to 35hz by using the 1/4 wave theory. The shared port would indeed be simply the 2 single ports combined.
However I'm not sure how it would sound as putting the subs in a sealed box would change their Fs. Build and test I suppose.
Old 09-18-2013, 05:24 PM
0/11 ssssss340
has anyone else tried this b4?
Old 09-18-2013, 05:57 PM
KickinBlazer's Avatar
0/11 sssss1122
no i dont believe anyone has tried it before....go ahead what would it hurt?
if its to loud your to old!
Old 09-18-2013, 06:02 PM
The proper way to use a transmission line is for increased bandwidth. Using it with a 4th order will basically give you a regular 4th order with a big port.
Transmission lines are not this magical spl box people think. 9/10 times a proper ported box will kill the t line on the meter. The t line is a sq box.
Old 09-18-2013, 11:19 PM
0/11 ssssss340
so im better off just doing a t-line by itself?
Old 09-19-2013, 09:43 PM
no, a tline isn't a spl box.
the box you somewhat described in your op could be related back to a front loaded horn. You would of course need expansion on the line area to gain anything over a regular 4th order. It will be a huge box and it is not easy, nor free to design one.
Old 09-19-2013, 10:00 PM
mega fatty
0/11 sssss6008
From the couple folded horns I've messed with they were as small or smaller then their equal ported (with 8's)
I found the proper port area on the sa8's I used ended up making the port huge so the folded horn was about the same size.
The horn had similar output around tuning but the horn did pass it up in the higher frequencies.
I found the horn needed a loading wall though. If I opened my hatch playing below the tuning the subs would bottom, hatch closed all was fine
Op have korey do a horn for you I think you will be very pleased with it
07 mazdaspeed3
rd d9 @ .5ohm
4th order/T-Line HT design bigdhenderson General Home Audio/Video 23 02-10-2013 12:31 AM
crazy 4th order/t-line idea robman General Car Audio Discussion & Questions 3 01-09-2013 09:00 PM
T-line, 4th order, or Rear Loaded Horn? 813thumper Enclosure Discussion & Design Construction Help 9 11-17-2011 09:11 AM
Subs for 4th order box???? Oldbass38 General Car Audio Discussion & Questions 23 10-19-2010 08:01 PM
