S Shaped Port? - Car Audio Classifieds!
Old 09-19-2013, 07:07 PM
0/11 sssss1330
Default S Shaped Port?
Hey everyone, long time no see. I've been out of the game for a while but I'm back.
I am getting ready to do my first trunk build and I have a question about the port for the enclosure I am designing. The box has a short depth so an "L" shaped port is not an option due to the mounting depth of the sub I am using. I am wondering if an "S" shaped port would be a suitable alternative, my main concern being that the air displaced by the sub would lose velocity.
Thoughts?
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 09-19-2013, 07:10 PM
0/11 ssss31258
it's not a concern. the air will flow fine even if you are only feeding it a few hundred watts.
Jolly Green Giant (09-19-2013)
Old 09-19-2013, 07:15 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Labyrinth slot port is what that basically is
Old 09-19-2013, 07:17 PM
massivespl's Avatar
0/11 sssss8409
box should work good. i built one just like that back in the day for a shitty lightning audio 10 and it slammed. i was shocked
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
Old 09-19-2013, 07:24 PM
0/11 sssss1330
Thanks everyone!
One last question...
If I wanted to make the box look more "aggressive" per se by making it look like it has a bigger port than it really is, would this have any effect on the tuning?
For example: My design above has a 2" wide port for 14 sq. in. of port area per cubic foot tuned to 30 Hz. What if I made the port 4" at the mouth and 2" through the rest of the box?
2010 Volkswagen CC
Old 09-19-2013, 07:27 PM
Authorized Vendor
0/11 ssss14115
Yes, it would change the tuning alot and make it hard to tune overall
Old 09-19-2013, 07:30 PM
massivespl's Avatar
0/11 sssss8409
keep it 2". the whole port
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-19-2013, 07:35 PM
0/11 ssss31258
you could make a flared opening. {like spy used to do} then it won't change much.
Old 09-19-2013, 07:37 PM
massivespl's Avatar
0/11 sssss8409
great idea
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-19-2013, 07:40 PM
0/11 sssss4519
I do flared opening on both ends I just account for them and tune accordingly
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
The Following User Says Thank You to LyferXB9s For This Useful Post:
Big jcc (09-19-2013)
Odd shaped bacon 2000LaDe Off Topic Chat 19 09-24-2012 11:16 PM
T-shaped slot port help whitetrash84 Enclosure Discussion & Design Construction Help 2 07-21-2012 06:52 PM
"T" shaped port? db xTc Enclosure Discussion & Design Construction Help 10 08-16-2011 07:10 PM
Anyone ever tryed using a port shaped like a T More spl Enclosure Discussion & Design Construction Help 7 04-25-2011 01:30 PM
L shaped box. Ok? LizP. Enclosure Discussion & Design Construction Help 8 01-31-2011 04:46 PM
