HDC3 15 d1 Box Design - Car Audio Classifieds!
Old 09-20-2013, 06:59 AM
0/11 sssssss21
Default HDC3 15 d1 Box Design
I want some advices on building a HDC3-15d1 box with folowing stats
Also,i would like to improve in some way the design.Maybe some tips with port tuning,changing,building,fixing port,another dimensions of box.
5cu ft net box.
6"Aeroport 15"long should be around 33-32 hz tuning.
Any ideas are welcome .Aiming SPL,wishing to change port size to hit a little of SQ also.
Thanks in advance.
PS:I got 9 cu ft of space plenty of room. 35 lenght 25 inches in width and 17 inches in height. Wont matter if I lower the backseat
SoundQubed reccomends 5^ft NET box with a 80sq" vent at 18" long.
Old 09-21-2013, 01:15 AM
0/11 sssss5305
I've had the best luck doing 4.25^3 for HDC 15's. Decent SQ and decent numbers when throwing some power at them...
Old 09-21-2013, 02:01 AM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
you will want more than a 6in aero.... and put it in no less than 4 cubes.
i had 3.... they HATED 3.35, and each had more port than a 6in per. Then i put them in 10 cubes for 2, and 1 8in tube per, they LOVED it and took 2kea daily and loved it.
Old 09-21-2013, 07:10 AM
0/11 sssssss21
They are good subs overall.HDC3s love big boxes i guess.
So 5cuf and 6 inch aeros or 8inch?i dont want much port noise
Because car is preety small : 2 doors hatchback ,port will end up mostly near front seats.
Old 09-28-2013, 03:37 AM
0/11 sssssss21
Bump !
After a few calculations i've came up with this measurements for port size
Volume of port would be 0.8 ft^3 and the aero would have 10"diameter and would be 18 inches long.
Should I go for smaller aero for it,or it would be ok for it to be 10"?I was thinking about 8 or even 6 "?
Any input would be greatly apreciated!
box design for 2 hdc3 10s on 4k fyerbyrd22 Enclosure Discussion & Design Construction Help 23 01-30-2013 03:33 PM
Box Design for 2 AQ HDC3 15s t1990le General Car Audio Discussion & Questions 2 03-13-2012 05:35 PM
Box Design Help for 2 hdc3 18"s 200dBs General Car Audio Discussion & Questions 30 12-13-2010 07:48 PM
Box design for 2 hdc3 15's, how does it look? Callmety General Car Audio Discussion & Questions 9 05-13-2010 08:21 PM
Box design for 2 Audioque HDC3 12s 3k+ RMS billystorms24 Enclosure Discussion & Design Construction Help 0 05-04-2010 10:28 PM
