6x6 slot port too small? - Car Audio Classifieds!
Old 09-20-2013, 07:51 AM
0/11 sssssss85
Default 6x6 slot port too small?
Hi,
Looking at going with a pair of SA8's in a circa 2.5 cubes, this leaves 1 cube for port if I go for maximum recommended enclosure size.
Is a 6x6 port tuned to 35hz enough for this box? Should I go bigger?
Box is for daily listening, mostly pop/chart stuff.
Old 09-20-2013, 08:27 AM
tntahoe's Avatar
0/11 sssss1196
it is enough imo, may even be too big
slot port or aero port tommytee General Car Audio Discussion & Questions 3 08-07-2011 09:17 PM
