need enclosure size for a 05' 12" RE xxx - Car Audio Classifieds!
Old 08-20-2009, 08:23 AM
resko1's Avatar
<<< atomic at7000.1d
0/11 sssss2134
Feedback Score: 21 reviews
Default need enclosure size for a 05' 12" RE xxx
I recently aquired a 05' model 12" RE xxx. I cant find any information on this so im just gonna ask everybody at the same time! lol. What size ported enclosure do i need for this? Running daily and I want max SPL but I also want it to hit low. Reccomendations on cu. ft. size, tuning freq., and psa( im gonna run my port with large surface and longer porting to increase power handling a little.
just an old fart
Old 08-20-2009, 07:31 PM
2.7ft tuned to 32hz with 50" of port
Old 08-21-2009, 08:46 AM
resko1's Avatar
0/11 sssss2134
Holay chit man! thats ALOT of psa. thats like almost 19sqin per cube. how did you come up with these specs?
just an old fart
Old 08-21-2009, 08:31 PM
spl_robb's Avatar
0/11 ssssss571
id say tune to 35hz 2.8cuft 40-45 sqin port to get both, or better , you can do removable port for the lows tune to 30hz and for spl 40-45 depending on your rides res freq.
this is one i had for 2 12"s with removable port.
i have 2 15" re 05 ss upgrade, box whas tuned to 32hz but whas nising some higher freq. on some songs that i like(hip-hop) so tuned to 36hz,diferent story, now i can get loud on the 40-50hz and more than decent on the lows
this is the one for the 2 15"s
Old 08-21-2009, 09:27 PM
resko1's Avatar
0/11 sssss2134
Nice build man! I actually just got an email back from Greg carolus at resonant engineereing. he recommended 2.5 cu ft tuned to 34hz and sent along design plans for a slot loaded enclosure.psa was 36 sq in, but i might bump that up to about 40 and lengthen the port.
just an old fart
Ideal enclosure and port size? DD 9515s westman995 Enclosure Discussion & Design Construction Help 6 09-18-2009 06:37 PM
15" RD Alpha Cutout Size? ChampagneCavalierTT General Car Audio Discussion & Questions 1 08-02-2009 05:38 PM
Enclosure Build: 15" for Matt Pioneer~Saturn Build Logs 21 07-24-2009 12:52 AM
8" TLINE enclosure RidnClean Build Logs 69 05-27-2009 01:03 AM
18" BTL enclosure aturcotte127317 Enclosure Discussion & Design Construction Help 4 01-10-2009 10:29 AM
