diamond audio d9 15 box help - Car Audio Classifieds!
Old 10-09-2013, 09:33 PM
0/11 sssss1364
Feedback Score: 25 reviews
Default diamond audio d9 15 box help
so i finally got my amp on the way which i have set back a long time but its coming. i cant decide want kind of box i want and if i can even do. i will have a diamond d6 1500 hooked up to it which i know it can handle but it should be nice after rise. i want would really like a 6th order but i doubt i have the room but a 4th would be fine. i have two options i can do Depth 30 Width 33 Height15 or Depth 24 Width33 Height 16. let me know what you think i can do and if i even cant do thoses ill do a ported box. not really good with box designs and im willing to pay someone but i want it done right and i can build it my self. also who is good with 4th or 6th order designs. i got my last couple by jtbuck and i was going to hit him up once i got help to see if i have enough room but would you recommend someone esle? thanks
specs for subs
http://www.diamondaudio.com/manuals/...sheet-2006.pdf
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
best box for a diamond audio d9 15 assassin1840 Enclosure Discussion & Design Construction Help 2 01-13-2013 06:17 PM
help with diamond audio d9 12 box assassin1840 Enclosure Discussion & Design Construction Help 4 02-18-2012 12:28 PM
2 15" diamond audio d915d2 new in box sancho20 15" Subwoofers 5 04-28-2011 10:50 PM
Diamond audio tdx12d4 box help wahvtec Enclosure Discussion & Design Construction Help 9 07-21-2010 04:04 PM
FS Diamond d9 12 LNIB+ box gsr22 12" Subwoofers 7 02-17-2009 01:33 PM
