4th order design - Car Audio Classifieds!
Old 10-17-2013, 09:41 PM
18psi's Avatar
0/11 ssssss500
Default 4th order design
Building in my 04 Cherokee
4 db drive k9 15's
Ct sounds 4000.1
Any 4th order guru's wanna chime in and help lol
I'm old skool pad an paper designer..
Dimensions 41w x 31h x 31-32d would be max dimension.
Help a fella out. I started a wall last weekend and had a hair brain idea of doing it in to sections---- fail...
So I'd take any and all advice and or design help... thanks fellas
Sent from my SPH-L710 using Tapatalk
Old 10-17-2013, 10:29 PM
0/11 ssssss131
im certainly not a guru ... but i have been reading every stinkin thing i could find between this site and others on 4th orders ...
my question to you is what is your goal ? your dimensions are a bit small for 4 15s so your sealed/ported ratio would be pretty small ... maybe around a 2-2.2:1 in turn giving you a wider bandwith but less efficiency ...
i just completed a 2.8:1 for two zv4 12's (my first 4th) and this thing moves more air than a back pack leaf blower haha
03 Tahoe
2 Zv4 12's on a CT 7k in a 4th
Old 10-17-2013, 10:38 PM
18psi's Avatar
0/11 ssssss500
I could go to like 40/44 deep. Just have to shrink height by maybe an inch or so.
Old 10-17-2013, 10:39 PM
18psi's Avatar
0/11 ssssss500
I've read a ton also. But still would like some insight.
Old 10-17-2013, 10:44 PM
0/11 ssssss131
my suggestion ... although im just starting to build and test myself ... would be to use all available space to get the ratio up ... hack seems to have alot of faith in the 3:1 ratio range and considering the numbers his builds have thrown up, i would say its a good starting ratio haha
03 Tahoe
Old 10-17-2013, 11:10 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You don't have to have a big ratio for it to play properly. Are you chasing numbers? Because numbers don't perfectly equate to audible loudness playing music, nor to how well it sounds.
Old 10-17-2013, 11:11 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I feel a lot of people build 4ths and really have no idea what they are doing. Or building a box that doesn't 100% make sense for their goals.
Old 10-18-2013, 08:12 AM
18psi's Avatar
0/11 ssssss500
Jt. I'm building it to play low, musical daily music. Lol
If it meters well so be it, but I swear when I had a setup do a 144 @21hz I enjoyed that more then high 150's in the 40hz and above ..
4th order design noknok Enclosure Discussion & Design Construction Help 29 02-04-2013 11:36 PM
$20 for a 4th order design right now via PP oxsign Enclosure Discussion & Design Construction Help 3 10-17-2011 11:14 PM
4th Order Design Help Silver-N-black Enclosure Discussion & Design Construction Help 9 08-24-2011 12:23 PM
4th order design bassbear007 General Car Audio Discussion & Questions 1 02-17-2011 07:57 PM
how to design 4th order xcaliber Enclosure Discussion & Design Construction Help 11 12-11-2010 05:48 PM
