Ported Box in Extended Cab Question - Car Audio Classifieds!
Old 10-21-2013, 12:13 PM
0/11 ssssssss5
Default Ported Box in Extended Cab Question
Hi guys I've searched and searched and I'm going to build a new box for my silverado extended cab. I have a sealed box in now that I'm not too proud of.
So. I have 2 Polk DB1040s because they were cheap and I don't have money right now. My box will be about 2 cu. ft. I want to use a 4in aeroport on the passenger side and there will be one sub on either side of the hump. a 4inx12in aeroport should get me close to 36hz tuning. They will be running off the sub channel of a pcx5800 which is about 400-500w rms. Does the shape of the box, big hump in the middle, have any effect on my tuning? and if I can't fit a 4" port due to space restraints can I stick a 3" port on each side as long as my port area stays the same?
Old 10-21-2013, 12:45 PM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
I say take out one of the seats and put in a couple big 10's or 12's, or a 15.
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Old 10-21-2013, 02:52 PM
0/11 ssssssss5
I would love bigger subs but I'm really trying to stay as stock as possible. I know it's not a competition truck and I don't have money for new equipment but theres a big sheet of MDF sitting in my garage
Old 10-29-2013, 09:56 PM
sgtskip's Avatar
Banannas are bad for you,
0/11 ssssss303
Default 2 10''s
I did this on my dads ford. I hope you can figure out fiberglass....
1. Remove everything of the rear seats. masking tape everything and then spray glue aluminum foil over everything so you can pull it out as you wish, its your mold.
2. Look at the fiberglass threads and practice. make small stuff, don't waste a lot on your 1st project, make a few...
3. Make the enclosure into two sides, it can be a 1 piece box but into separate enclosures. Place the subs and figure out the port mounting, 90* port. Ported will work best unless you are going to run power.
skip
Hate being Bi-Polar...... its Friggen Awesome
Old 10-29-2013, 10:12 PM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
i know it doesnt help a ton, but i second the rear seat being taken out. it is useless anyway.
Old 10-30-2013, 12:01 AM
sgtskip's Avatar
0/11 ssssss303
trim the bottom of the seat out of cardboard, use that as the top of your mold. the front should be 3/4 in, all the way across add 2nd layer on the back of the front. glass the bottom to the front, sides, middle and back..... that should be one piece, mold the top to fit and make it thick.
have fun
skip
Old 10-30-2013, 12:11 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Yes it will be fine, go 12.5 each
01 Volkswagen Golf 2 door
Kenwood ddx470
FOUR Brand New Sundown Audio SA-8 V.2 RARE Stock SPL Version & GM Crew Cab Ported Box Texas Edition 8" Subwoofers 21 04-24-2013 09:53 AM
BESt 10" sUB FOR EXTENDED cab?? Jesus805 General Car Audio Discussion & Questions 4 10-01-2012 12:47 PM
1988 - 1998 Chevrolet / GMC Extended Cab Truck Stealth Box rikyf121881 Wiring, Electrical & Other Installation Equipment 1 01-05-2010 12:07 AM
box design for extended cab tundra michael707 Enclosure Discussion & Design Construction Help 1 01-02-2010 08:56 PM
Best Box Position for Extended Cab trucks snow90 General Car Audio Discussion & Questions 13 09-23-2009 03:08 PM
