SS XXX 15 enclosure - Car Audio Classifieds!
Old 10-22-2013, 07:54 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Default SS XXX 15 enclosure
I am needing someone who can do a design for me, my current box designer is not able to do it for me and I need it before Friday. Sub is a single sound stream xxx 15. Vehicle is a 2008 Chevy Silverado extended cab enclosure will replace the 40 portion of the rear 60/40 seat. The dimensions to work with are 17" wide, 34" height, and 21" deep. I have 2 4" aeros to use to save space. Would like to tune @ 30 hrtz. Im not asking for a free design as I will pay for this.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 10-23-2013, 09:51 PM
1loudmonte's Avatar
0/11 sssss2167
Anyone willing to help.
Old 10-23-2013, 10:00 PM
0/11 ssssss200
how long are the aeros? I can probably help you
Old 10-23-2013, 10:03 PM
0/11 ssssss137
well according to your dimensions the box comes out to 5.68 cu ft if you use .75 inch thick wood.
If you use 2 aero ports at 4 inch diameter, 10 inches long, it tunes the box to 30 hz. (the port area is pretty small with 2 4" ports, it only amounts to 25 inches port area .. 1 port at 8 inches diameter at 24 inches long gets you 30 hz and 50 inches of port area total.)
Simple design like that would work. either would work, those are with 4 inch diameter ports at 10 inches long. (but again port area is rather low)
Old 10-23-2013, 10:06 PM
0/11 ssssss200
Optimal cubes would be about 4.5 according to sound stream
Old 10-23-2013, 10:09 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Those subs love big boxes
Sent from my SCH-I605 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 10-23-2013, 10:23 PM
0/11 ssssss200
Big Boxes tune LOOOWWWW
Old 10-29-2013, 11:46 AM
0/11 sssssss26
I've heared lots of SS XXX; I don't know if they really like to be tuned low. They move lots of air, but they're not good with music IMO. Good for rap or simple bass lines songs, but really not musical subs.
They're super expensive locally, and they claim 6500 or 8000 w rms !!!! More than 3000 : they won't like that for long
Be careful.
Re xxx xbl^ for home theater enclosure? Eocuph General Car Audio Discussion & Questions 27 10-07-2013 12:20 PM
1 RE Audio XXX 15 Dual 2 Ohm Sub- W/Enclosure if you want it. cant_get_ryte 15" Subwoofers 3 11-20-2011 09:00 PM
Enclosure build for a 18" Soundstream XXX BKNIGHTS Build Logs 17 09-02-2011 10:29 PM
need enclosure size for a 05' 12" RE xxx resko1 Enclosure Discussion & Design Construction Help 4 08-21-2009 09:27 PM
Enclosure for 2 15 XXX Silver-N-black Enclosure Discussion & Design Construction Help 10 04-28-2009 12:32 PM
