SunFi Enclosure Help - Car Audio Classifieds!
Old 10-22-2013, 08:57 PM
TEAMWOOFERS & TEAMXPLICIT
0/11 sssss3841
Feedback Score: 22 reviews
Default SunFi Enclosure Help
Hi all I have a question on what the enclosure's dimensions would be for these two 18" SunFi(Fi & Sundown) woofers in a wall. Here's what I have so far planned:
Max Dimensions are 54"Wx33"Dx40"H
I'm planning on triple layering the front and back then double layering the top, bottom, and sides.
Orientation will be subs on the sides and slot port in the middle vertically.
Powered by two AQ3500.1D's one on each sub.
Tuned in the range of 36-38hz.
Subs are BTL UFO Motors, ZV3 soft parts, and NS spiders.
D1 Coils
What should I be looking at interior volume? Anything helpful to this would be much appreciated!
wow, i really wasnt expecting that many people to pick ed over jacob? with the way people jock sundown around here
[email protected]
Old 10-22-2013, 09:13 PM
0/11 ssss31258
build the wall. your airspace doesn't matter. (it's not going to get bigger just because you might want it to)
Old 10-22-2013, 09:16 PM
0/11 sssss3841
I'm just trying to figure out what the dimensions would be for the wall. Some things I need help figuring out is port size, length, overall wall dimensions, and I guess I'm still trying to figure out what kind of tuning I should shoot for.
[email protected]
Old 10-22-2013, 10:13 PM
0/11 ssss31258
you said 36-38hz. it'll work.. and tuning high like that, you won't be disappointed with the numbers.
As I said, the volume doesn't matter. and the tuning is 'your guess'. [no one can tell you for sure what your subs 'ARE' since they are Hodge-poge]
The balancing act is port vs box volume.
get the shell built and then figure out the port and face.
Old 10-22-2013, 10:16 PM
0/11 sssss3841
I guess my biggest question is what size should the shell be. Obviously full width and height but depth is my question because if I use up all the space that means it will be angled in the back on the top and bottom.
Btw I am tuning in that range because I listen to multiple genres of music and would love it to be loud in as big of a range as possible.
[email protected]
Old 10-22-2013, 10:21 PM
0/11 ssss31258
build the shell as large internally as you can. Angled is fine.
Enclosure Build: 12" 'standardized' daily enclosure, Dougie style Pioneer~Saturn Build Logs 59 05-20-2013 05:32 PM
Enclosure Build: 10" IAD Reign Demo Enclosure ;) Pioneer~Saturn Build Logs 57 11-18-2012 02:58 PM
What do you think of this enclosure? Wes669 General Car Audio Discussion & Questions 27 07-29-2011 02:22 PM
Help with enclosure PSI Poundin Enclosure Discussion & Design Construction Help 1 08-22-2010 03:42 AM
