Single 12" JL 12w6v2d4 with 6" aero port - Car Audio Classifieds!
Old 10-27-2013, 04:07 PM
0/11 ssssss194
Default Single 12" JL 12w6v2d4 with 6" aero port
I've just recently started flirting with the idea of building a box for my JL 12w6. I want to use a 6" aero that I was gonna use in another build.
This is a new design for me since I've never used a 6" aero, so I'm curious how to build a box tuned to about 32-33 hz using 3/4 birch wood.
Here's the specs on the sub:
Free Air Resonance (Fs) 25.0 Hz
Electrical Q (Qes) 0.48
Mechanical Q (Qms) 7.1
Total Speaker Q (Qts) 0.45
Equivalent Compliance (Vas) 2.82 cu ft / 79.9 L
One-Way Linear Excursion (Xmax)* 0.65 in / 17 mm
Reference Efficiency (no) 0.25%
Efficiency (1 W / 1 m)** 85.9 dB SPL
Effective Piston Area (Sd) 77.8 sq in / 0.0502 sq m
DC Resistance (Re)*** 6.75 Ω
My aero is in 3 pieces. The longest part is 12", one flared end measures 4", the other 4.75.
Thanks for any help, fellas.
Aero Port Advice for single 12" PSI plat 2 Eth anol General Car Audio Discussion & Questions 0 09-25-2012 11:05 PM
10" aero port is way louder with the zv3 18"s than the 8" aero Mnorwood01 (Sundown Audio) 34 06-28-2012 04:00 PM
Aero Port Displacement: 8" on 2 LVL 4 XL 15s" 528hz (DC) 20 07-23-2011 02:55 AM
3ft 8"aero with port plug box and 2 10" Power hx2 recones amartin_72 Build Logs 3 03-09-2011 09:18 PM
[SOLD] Part express 4" "aero" port orangelss Speaker Accessories & Parts 2 10-31-2009 11:37 AM
