Fiberglass help - Car Audio Classifieds!
Old 10-30-2013, 03:40 PM
0/11 ssssss857
Default Fiberglass help
I have my order of speaker rings and speakers coming in. Just a quick question for any fabricators out there. What fabric do u suggest using to lay over the rings in the door panel? I was thinking felt but wasn't definite. Thanks
Old 10-30-2013, 04:37 PM
socalxj's Avatar
0/11 sssss2371
The most popular fabric is speaker grill cloth by far. Speaker Grill Cloth Black Yard 70" Wide 260-335
Another fabric that you might actually have is a polyester cotton blend tee. Any fabric that stretches in all 4 directions should work fine. Just be careful not to over catalyze resin to prevent it from cracking! Good luck if I had the time I'd post a how to but my time is limited presently. will post up when I get caught up... hopefully before I die!
Old 10-30-2013, 04:42 PM
0/11 sssss1475
Fleece is what you are looking for. Or a old tshirt or pretty much any stretchy fabric. You also want to plug the holes with wood wrapped in foil to keep them from getting resin on the inside and from getting stuck. Once that hardens turn it over n go ham with resin n glass on the inside.
Old 10-30-2013, 04:48 PM
0/11 ssssss857
Thank you guys, first time wrapping doors. The typical polyester resin will work for these applications?
Old 10-30-2013, 04:52 PM
0/11 ssssss822
Ponte fabric stretches very well and uses less resin then fleece
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Old 10-30-2013, 04:59 PM
socalxj's Avatar
0/11 sssss2371
Yes! Polyester resin...Bondo® Polyester Fiberglass Resin (401) - Body Repair - Ace Hardware
The fiberglass should be lay up glass the tight woven type not the mat or course weave
Old 10-30-2013, 05:23 PM
0/11 ssssss857
Can u link me to type that u are talking about for lay up glass? I actually work for ace so I can get it cheap, so if u know of the product on ace that be cool. Thanks.
Old 10-30-2013, 06:42 PM
socalxj's Avatar
0/11 sssss2371
Here you go...Bondo® Fiberglass Cloth (499) - Body Repair - Ace Hardware
Old 10-30-2013, 06:52 PM
0/11 ssssss857
Thanks bud. I'll order those two things at work tomorrow.
Fiberglass theking General Car Audio Discussion & Questions 15 06-15-2012 04:14 PM
Someone who can fiberglass gcguy2169 General Car Audio Discussion & Questions 2 06-08-2012 04:21 PM
Need fiberglass help please. lunchbox General Car Audio Discussion & Questions 26 06-02-2012 03:52 PM
Fiberglass DonH General Car Audio Discussion & Questions 41 11-13-2010 10:11 AM
How to fiberglass davidrforbus Tutorials & Quick References 2 06-03-2010 01:21 AM
