how does this look? - Car Audio Classifieds!
Old 10-30-2013, 05:09 PM
0/11 sssssss84
Default how does this look?
going in the back of an extended cab f150, subs up, ports firing to passenger side, want it to dig really low
Old 10-30-2013, 05:14 PM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
can you get a better quality screen shot. I could not read this even zooming in.
Old 10-30-2013, 05:15 PM
0/11 sssssss84
not sure how :/ new to this
Old 10-30-2013, 05:20 PM
0/11 sssssss84
better?
nevermind -_-
basically-
height-20
width-30
depth-16
2x4" aero ports 17" long
net volume- 3.68 ft3
Old 10-30-2013, 05:29 PM
CACO SLACKER
0/11 ssssss597
what sub(s)/amp(s), wattage?
Old 10-30-2013, 05:39 PM
0/11 sssssss84
2 sa12s on american bass ph4000md, getting 1000 watts each
Old 10-30-2013, 06:01 PM
30hz&below
0/11 ssssss287
They are a little pricy but I'd use a single 6" aero from psp for a little more port area
Old 10-30-2013, 06:14 PM
CACO SLACKER
0/11 ssssss597
also for those, unless my math is fuzzy(which after that day at work it could be) the box seems a little big for that power
Old 10-30-2013, 06:23 PM
0/11 sssssss84
1 6" is more area than 2 4"??
Would 3 .5 ft3 be better? Or even 3ft3?
Old 10-30-2013, 06:35 PM
30hz&below
0/11 ssssss287
Yes. Use formula pi*r^2
1 6" = 28.26
2 4's = 25.12
Then divide those numbers by the cu. ft. of your box and it should give you your sq. in. Per ft. I am still getting familiar with aeros myself but I have done a lot of research so if I messed up someone please correct me haha
